Brakes?
  • dumb_dom
10 Mar 2017 12:30 - 10 Mar 2017 20:30 #179024 by dumb_dom
Brakes? was created by dumb_dom
Hey guys so over recently bought a new jimny and while checking it over after owning it for a few months I've noticed the front disk is half getting rust, kind like the bottom half of the pad isn't touching during braking, also when spinning the front wheel while raised in the air you can hear them slightly skimming/catching the rotar..any ideas?
Last edit: 10 Mar 2017 20:30 by mlines.
10 Mar 2017 15:38 #179033 by Keithy
Replied by Keithy on topic Brakes?
Looks to be a grey area.....all over the image! :D
If you can get the rust off try some new pads.....not saying to put sandpaper between the new pad and disc to remove the rust as you'd need to remember to remove it before hitting the highway......discs are pretty cheap as it happens....make sure the calliper slides freely.
The following user(s) said Thank You: dumb_dom
  • dumb_dom
10 Mar 2017 16:28 #179034 by dumb_dom
Replied by dumb_dom on topic Brakes?
I don't think I'd even fit plane paper between the pad and disk the gap is that tight, I was thinking it could be seized guid pin or not %100 functional ones at least, I'm not that hands on when it comes to brakes it the only thing I don't tend to tinker with myself as if you bugger it up it can be dangerous
As for the image I have. O idea why it's dooing that, I've tried editing and re-uploading but it's the same
  • gusthegorilla
10 Mar 2017 16:54 #179037 by gusthegorilla
Replied by gusthegorilla on topic Brakes?
[quote=
As for the image I have. O idea why it's dooing that, I've tried editing and re-uploading but it's the same[/quote]
Try using Photobucket or similar, it sizes them correctly for posting...
Gus
10 Mar 2017 17:32 #179042 by mlines
Replied by mlines on topic Re:Brakes?
Can you email the image directly to me, I am trying to track the issue down, martin@lines-family.com
Sent from my Nexus 6P using Tapatalk
  • dumb_dom
10 Mar 2017 18:19 - 10 Mar 2017 18:21 #179044 by dumb_dom
Replied by dumb_dom on topic Re:Brakes?
Sure mlines no problem, If it helps its uploaded via iPhone
Last edit: 10 Mar 2017 18:21 by dumb_dom.
Time to create page: 0.121 seconds
