Kingpin Bearings
- Scot The Sniper
- Senior Member
- Thank you received: 4
09 Mar 2017 22:11 #179016
by Scot The Sniper
Kingpin Bearings was created by Scot The Sniper
hi gonna do these at the weekend whats the story with the shims. never done one before but hear the mention of shims in them is it shim as in one shim or a few shims and whats the theory behind putting shims in?
thx in advance
jimny 1.3 04 plate
thx in advance
jimny 1.3 04 plate
10 Mar 2017 06:27 #179017
Replied by mlines on topic Kingpin Bearings
As standard the Jimny does not have shims fitted. However, slight wear over the years in the hub means that play can occur which is still there when the bearings have been changed. You could also then change the Kingpins themselves but even this does not always remove all the play due to wear.
Therefore small shims can take up this slack, even Suzuki now have shims for the "shimless" design.
Shims are here: www.bigjimny.com/store/king-pin-shim-kit-suzuki-jimny.html
Bearings are here: www.bigjimny.com/store/kingpin-bearing-k...zuki-jimny-koyo.html
Time to create page: 0.079 seconds
