G13BB Crankshaft sensor
- TomDK
24 Feb 2017 22:40 #178491
by TomDK
G13BB Crankshaft sensor was created by TomDK
Hi
Can anyone tell me the resistance of a G13BB crankshaft sensor. It's a type J5T10771.
I'm measuring 400 Ohm's. But not sure it's enough
And google is of no help
Tom
Tom
- mickt
25 Feb 2017 18:45 #178512
by mickt
Replied by mickt on topic G13BB Crankshaft sensor
I have my engine apart and will try and dig it out if you are not in a hurry. But I did a google search on crankshaft position sensor and there was a \you tube clip that shows a chap testing a sensor and he reckons the reading should be between 200-500 ohms. Then he reckons to fit it with the test leads fitted and crank the engine and with volts selected to ac you should see 0.2 to 2volts
- TomDK
25 Feb 2017 19:44 #178518
by TomDK
Replied by TomDK on topic G13BB Crankshaft sensor
Thanks
Not in that much of a hurry. I found some info on the sensor on a Geo Metro forum. The CKP resistance is supposed to be around 360-460 ohms. So the sensor I have should be ok. But still getting engine light on and reading CKP error on the tester.
- mickt
25 Feb 2017 19:55 #178520
by mickt
What does CKP stand for?
- TomDK
25 Feb 2017 20:06 #178522
by TomDK
Crankshaft Position Sensor.
Time to create page: 0.090 seconds
