droping the sump
- larnach
20 Feb 2017 23:48 #178311
by larnach
droping the sump was created by larnach
Hi
I am new to the Jimny world and discovered my sump is like a tea bag
the Jimny is up on stands and looks like it will drop from underneath without having to lift the motor
am I right and what is involved
its a 2006 VVT Mode model
26 Feb 2017 09:04 #178539
by Mike G
2" Trailmaster suspension lift, 2"body lift, snorkel, full breather kit, 29" steel wheels with BFG tyres, tinted rear windows, CRT CB radio with modulator antenna mounted on rear, dog cage and tray in the back.
Replied by Mike G on topic droping the sump
I changed the sump on my old jimny which was a G13 engine. From what I remember it was a bit awkward, I stuck it on axle stands and undid all the bolts on the sump. They were covered in oil so no problem to get out. However, when it came to taking the sump out from underneath, I needed to use a scissor jack to jack the axle away from the body of the car enough to squeeze it through the gap between the axle and the engine. Remember there's a spill pick up in the sump to get past too.
26 Feb 2017 10:10 #178546
Replied by mlines on topic droping the sump
- larnach
26 Feb 2017 13:28 #178556
by larnach
Replied by larnach on topic dropping the sump update
T[hank you Flash for the contact and info share,
I had lost faith or assumed nobody knew considering how many viewings this post has had I was surprised, ( it was maybe a secrete ??)
Anyway the sump is off, I have the hubs stripped and the track rod bar out anyway, not actually sure if it would have hindered, never the less
bolt access is very easy, there is one slightly awkward one but have a modified socket so no probs at all
Took my time getting the sealant to release and the thing fell to the ground ( mine is an M13AA engine)
have run the tap and die to clean out the threads in preparation for a new sump
I am just looking at a list Martin, thanks for the advert though
Time to create page: 0.090 seconds
