Wrong rear diff
- bodsjim
31 Jan 2017 17:31 #177563
by bodsjim
Wrong rear diff was created by bodsjim
Hi all , I've just bought my first Jimmy its a 53 plate mode with 40k on the clock . Thing is it's got a problem the previous owner damaged the rear axle and replaced it with an axle from an automatic model ( mines a manual ) . I haven't tried the car in 4wd he's told me not to use the 4wd as it winds up ? I'm new to 4wd so my question is is the reason why it winds up due to the incorrect diff being fitted ? If so what's the best resolution , should I change the whole rear axle or is there a smaller job that can be done to rectify the issue . Thanks in advance for your help
31 Jan 2017 17:41 #177564
by j999pre
Grey pick up Jimny
Replied by j999pre on topic Wrong rear diff
You can just change the diff. Not a difficult task but will mean bleeding the brakes as both rear shafts will need to be moved to get the diff out. If you need a diff I have one. The auto is 4.1 a manual on that year would be 3.9 hence the wind up.
Grey pick up Jimny
31 Jan 2017 17:47 - 31 Jan 2017 17:50 #177565
Replied by mlines on topic Re:Wrong rear diff
Leaving the diff aside for a minute. The previous owner is basically correct. Do not use 4wd on road as it will wind up. Only use it on slippery surfaces where the tension will release itself.
Back to the diff, James is correct the ratios are different but in a part time system as fitted to a Jimny this is more an issue around road speed and clutch wear on the road, not wind up
Sent from my Nexus 6P using Tapatalk
Last edit: 31 Jan 2017 17:50 by mlines.
- bodsjim
31 Jan 2017 19:57 #177580
by bodsjim
Replied by bodsjim on topic Wrong rear diff
Sent you a pm
Time to create page: 0.080 seconds
