Shock extenders question
- wilku
30 Jan 2017 17:24 #177526
by wilku
Shock extenders question was created by wilku
I've decided to start lifting my Jimny with an extender kit. All the kits I can see on the Internet have a U-shaped spacer for the bottom mount of the rear shocks and a screw extension for the top mounting of the front shocks. Is there any particular reason for the solution on the front? Or, in other words - will 4 extenders of the "rear" type work as well?
(Of course I'll also add polyurethane spring extenders to match the shock extension brackets)
- Thank you received: 706
30 Jan 2017 17:59 #177531
Replied by jackonlyjack on topic Shock extenders question
No eBay APP ID and/or Cert ID defined in Kunena configurationIf you are on facebook Richard Fox is your man
these are his if you contact him through FB you may get them for a little less
Jack
Jack
- wilku
30 Jan 2017 19:14 #177532
by wilku
Replied by wilku on topic Shock extenders question
Thanks, but I've already ordered them locally for a pretty much same price (mine will be powder coated though - the workshop also has a paintshop so they'll hang next to some other, more serious job).
Although I've ordered 4 of equal size - why do these differ? (or is it just perspective?)
30 Jan 2017 19:36 - 30 Jan 2017 19:37 #177533
Replied by mlines on topic Shock extenders question
The rear ones will not fit the front and shock extenders do not lift your 4x4
Last edit: 30 Jan 2017 19:37 by mlines.
- 1066Boy
30 Jan 2017 20:48 #177534
by 1066Boy
Replied by 1066Boy on topic Shock extenders question
You will gain a bit of extra flex with them on the rear. Removing the ARB on the front
will help match the rear.
30 Jan 2017 23:11 #177540
by Busta
Replied by Busta on topic Shock extenders question
Don't fit shock extenders unless you are fitting a matching set of spring spacers.
