Replacing Rear Engine Mount Video
  • Daniel30
27 Jan 2017 08:20 #177339 by Daniel30
Replied by Daniel30 on topic Replacing Rear Engine Mount Video
Great vid
Thanks for sharing ;)
27 Jan 2017 11:00 #177343 by Keithy
It's a task getting fingers where you got the camera!
nice one!!
  • mickt
27 Jan 2017 13:58 #177350 by mickt
Replied by mickt on topic Replacing Rear Engine Mount Video
Just a couple of points. First if money is tight you can re-glue the rubber back to the mounting or you can order one off the internet a bit cheaper. The one I got did not have captive nuts for the chassis mount bolts but I just used a couple of new bolts with lock nuts.
  • Damo666
27 Jan 2017 14:25 #177354 by Damo666
Replied by Damo666 on topic Replacing Rear Engine Mount Video
I'm not sure I'd be happy glueing it....but it's worth a go I suppose. The part from the dealer was only about £30 though so that's not going to break the bank....that had the captive nuts all on there ready so less faffing.
28 Jan 2017 16:36 #177423 by facade
Nice video. B)
The captive nuts are the difference between the "Genuine Suzuki" and the "Genuine Suzuki from China off eBay" part.
When I did mine I tightened the centre bolt, then pushed the gearbox up and dropped it down to see how far out the holes were, then I slackened off the front engine mounts and moved the gearbox until I could lift and drop it and the holes stayed in line.
Then I tightened the fronts and fitted the rear bolts.
I reckon any misalignment will strain the rubber and make it break again- I want at least another 15 years out of it :)
OT, but I bought a set of "Genuine Suzuki" transfer box mounts cheap, and they were boxed and hologrammed Maruti - made in India!
  • Iaitoo
03 Sep 2017 02:58 #183825 by Iaitoo
Replied by Iaitoo on topic Replacing Rear Engine Mount Video
Is it random which mount that is used? Do I have to go under the car to check which mount I have to order for my g13bb jimny? :p
Time to create page: 0.122 seconds
