SQUEALING!!!
  • Delve
26 Jan 2017 09:53 #177291 by Delve
SQUEALING!!! was created by Delve
Hi all. Not had my jimny long and i'm trying to sort through the mountain of problems that have come up!
But today's topic is squealing.
I took the jimny in for a major service, cam belt, water pump and both fan belts. Before the service it squealed when I put the lights on, heater on full etc......... and it still does it with new belts. Any ideas........? It's been 9 days since the service. I got a new battery a few weeks ago as the old one went flat over winter and none use. My local garage didn't have the correct battery for it so i got one he said would do fine (i needed the car that day) but there's quite a difference in the outputs, 300 cca and 35ah...... could this be a cause of the noise? I have got to the point I have to pick whether i want a bit of heat or lights! Also, at night the headlights hardly work. I've put in osram night-breakers and still i get only a few feet when going down the road. I've noticed on the plastic cam belt cover the fan belt at some point has been rubbing against it and its made a fairly substantial groove.
My list of problems:
The squealing
Brake lines corroded
Fuel line corroded
Sticking drivers seat belt (drives me mad!)
Sills rotted at the rear both sides
Centre section of the exhaust, the bracket has fallen off
Front roof bow disintegrated
Front roof vinyl leaks
4WD light flashing
No light on the dash for full beam
A couple of really bad rust patches on the inner arches at the front that are almost holes
And i save the worst for last......... a previous owner has striped the thread when putting in a spark plug and used a helicoil..... which has fused to the spark plug so the helicoil comes out with it.....
Any help will be very much appreciated!
  • Young Pretender
26 Jan 2017 13:35 #177299 by Young Pretender
Replied by Young Pretender on topic SQUEALING!!!
Blimey that's a list there mate :blink:
I have the same problem re squealing. The fan belts may not be tight enough so slipping on the pulleys. However if they are tight enough then you could have what appears to be a very common fault with the crank pulley (the very bottom one). Apparently they have a rubber section in the middle which delaminates and makes the belt slip - the pulley is also prone to falling apart.
I'm in two minds whether to change mine before it breaks or wait. I will probably change it soon because the squealing is annoying. You can get some sticky belt spray which helps for a few days but it does make a mess.
The pulley is approx. £150 for OEM part and £90 for an ebay version. Given that we know the OEM part is poorly designed I'm not sure it's worth the stretch personally. Fitting is apparently quite tricky but can't help on that front yet.
  • mickt
26 Jan 2017 13:39 #177300 by mickt
Replied by mickt on topic SQUEALING!!!
If you wait till it breaks you risk the chance of overheating and knackering the head gasket and even more! And that is apart from being stranded and not drivable due no water cooling, no battery charging and no power steering!! Thebelts can whip and damage the rad too! Why chance it??
  • Young Pretender
26 Jan 2017 13:43 #177302 by Young Pretender
Yes you are absolutely right
  • Daniel30
26 Jan 2017 13:56 #177303 by Daniel30
Replied by Daniel30 on topic SQUEALING!!!
I have the problem at the moment which is definitely heading towards the crankshaft pulley, try and upload a clip of the noise as a belt will be a different sound to the pulley, I had the belt issue about 6 months ago but mine was sorted by changing the belts which you could see had little cracks in them.
  • Delve
26 Jan 2017 18:47 #177310 by Delve
Replied by Delve on topic SQUEALING!!!
If it was the pulley starting to fail, would it only make the squealing noise under a high electrical load? it mainly makes the noise while pulling away and driving slowly etc. most of the time i can stop it briefly by dipping in the clutch and revving.
would the battery I've got on it be any factor at all?
Thanks for all the advise so far
i'll upload a video of it tomorrow
Time to create page: 0.103 seconds
