Weird noise
  • Daniel30
24 Jan 2017 10:00 #177207 by Daniel30
Weird noise was created by Daniel30
Noticed a weird noise when I first start the Jim from cold, it's as if there is something stuck to one of the belts it gets faster when I rev it but then goes away after a few minutes and if I park up then start it again it's not there only seems to happen when cold? Any ideas?
I'm going to start it in a few hours and see if it's there.
24 Jan 2017 11:20 #177209 by Keithy
Replied by Keithy on topic Weird noise
Vicous fan?
  • Daniel30
24 Jan 2017 11:30 #177210 by Daniel30
Replied by Daniel30 on topic Weird noise
Would this have a bearing in it or something Keithy? And settles when it rotates for a bit?
24 Jan 2017 12:13 #177212 by Keithy
It is fully engaged when first started.....then the fluid moves away from the inner vanes after around a minute.
Only time it re-engages is if the spring gets warm and rotates the engage mech/valve.
I'd start the car with the bonnet up when cold and have a proper look.
  • Daniel30
24 Jan 2017 12:21 #177214 by Daniel30
Ok thanks, had to pop out about an hour after I started it this morning and no noise. Will try and listen for it in the morning
  • Daniel30
24 Jan 2017 14:15 #177217 by Daniel30
Will post one on in the morning as well you can hear it a bit in this clip but louder in the morning
Time to create page: 0.101 seconds
