Spark plug hole rethreading
- Damo666
12 Jan 2017 18:53 #176676
by Damo666
Spark plug hole rethreading was created by Damo666
A little while back I asked about fixing a rear engine mount and this possibly causing lumpy tickover on my other half's 2003 Jimny. Well the mount is sorted and the problem was still there. In the absence of a code reader I thought it felt like it was misfiring so I went old school and started checking the plugs....
Yep, here was the problem, pulled out the second lead/coil pack in from the front and the lead had all but disintegrated or something and was just touching the spark plug with a thin bit of wire.......easy fix, new coil pack. The BIG problem I have is the spark plug had become that loose that it has now stripped the threads in the head and in the process lost its 4 electrodes off the end of the spark plug (out the exhaust hopefully!)
Has anyone had any experience of this or of using Helicoils to repair it and if so what size am I going to need? HELP!
Thanks
Damo
Thanks
Damo
- OllieNZ
12 Jan 2017 19:47 #176685
by OllieNZ
Replied by OllieNZ on topic Spark plug hole rethreading
- mickt
12 Jan 2017 20:17 #176696
by mickt
Replied by mickt on topic Spark plug hole rethreading
Ouch! It would be easier and quicker to get a replacement head. James (j99PRE) might be able to help.
12 Jan 2017 20:36 #176700
Replied by mlines on topic Re:Spark plug hole rethreading
There are a number of repair services around the country, here is my local one
www.threaddoctorservicesltd.co.uk
Sent from my Nexus 6P using Tapatalk
- Damo666
12 Jan 2017 20:53 #176710
by Damo666
Replied by Damo666 on topic Re:Spark plug hole rethreading
Any idea on what sort of price I'd be looking at to get it done? Wonder whether it is worth just sourcing a new head?
- Thank you received: 706
12 Jan 2017 23:18 - 12 Jan 2017 23:19 #176726
Replied by jackonlyjack on topic Re:Spark plug hole rethreading
i have a M13A head still on the engine just let me know if you want it
and i will remove it to check condition £25 plus postage
Jack
Jack
Last edit: 12 Jan 2017 23:19 by jackonlyjack.
