Possible front abs sensor alternative?
  • Justin83
09 Jan 2017 17:20 #176450 by Justin83
Possible front abs sensor alternative? was created by Justin83
Hello everyone, it seems I have an issue with my front left abs sensor and as most of you will know they come as a joined pair at £200+ quid!!
Basically after reading about rears or Mazda abs sensors possibly being able to be spliced in I've looked at images and they look different...
Well after looking through some other Suzuki models it seems Liana rears look exactly the same and cost £20 each, gotta be worth a shot.
Guessing no one else has got around a £220 quid bill?
  • Justin83
09 Jan 2017 17:23 #176452 by Justin83
Replied by Justin83 on topic Possible front abs sensor alternative?
Jimny above
Liana below...
  • Justin83
09 Jan 2017 17:25 #176453 by Justin83
I don't get it, is there any logical reason why if they can sell one for £20 why isn't x2 with some extra cable and brackets 40-50 quid!?
Am I missing something?
  • Justin83
10 Jan 2017 22:15 #176543 by Justin83
Tumble weeds blow through lol...
Well I've ordered the Liana one so we will see and maybe this thread can save some people some money, hopefully.
  • Justin83
01 Feb 2017 07:09 #177600 by Justin83
Well I broke the Liana one but I think it would have worked, basically there's a plastic bit that stops it seating squarely, I bolted it on and there was no abs light, when for a drive and it fouled the abs cog and damaged the sensor...
Its because it wasn't square, I later cut this plastic bit off with a Stanley knife and it seated perfectly but it was already damaged... I'm 95% sure that would have worked.
I then added instant gasket to the wire on the old sensor where it enters the sensor itself and this has fixed the old sensor, I guess water was getting in there hence the abs light only active in the rain/wet.
Hope this helps others somewhat, if you try the Liana sensor and it works please post it here.
