Link vs Radius Arm Setup
  • OllieNZ
08 Jan 2017 20:44 #176407 by OllieNZ
Replied by OllieNZ on topic Link vs Radius Arm Setup
Those dimensions are roughly stock, I'm looking at the lower links being something like 30" (760mm) and the upper being 27"(685mm) I still need to get out and take some proper measurements to get the numbers closer
  • TomDK
10 Jan 2017 01:20 #176493 by TomDK
Replied by TomDK on topic Link vs Radius Arm Setup
4-link seems the best way to go I you know what you're doing and getting all calculations right.
But on some of these builds, right calculations or not. I really don't understand why some people want to go through all this work of doing a 3 or 4 link only to put cheap shocks on it. It doesn't make sense. A suspension of either of these types need som proper shocks, coilovers or airshocks perhaps.
  • OllieNZ
10 Jan 2017 18:27 #176522 by OllieNZ
Rich wrote: As Keith mentioned I've been looking into fitting a 3link under mine but it might be good to note that you will get rear steer depending on your rear panhard.
I have no tank or exhaust in way under mine to cause any restrictions and after several days of reading the benefits between 3 and 4 that I am now more inclined to go with a 4 link as they seem to have better handling and more predictable when built properly
Attachment not found
This pic is someone on the forum currently building a 4 link in a jimny chassis
Thanks Rich,
I'd spotted that one, landrover axles iirc.
Would you mind elaborating(or linking a discussion) on the 3 vs 4 link, from what I've read so far a properly set up 3 link shouldn't have any issues with rear steer.......
  • OllieNZ
10 Jan 2017 18:31 #176523 by OllieNZ
TomDK wrote: 4-link seems the best way to go I you know what you're doing and getting all calculations right.
I don't know if my budget will stretch to coil overs but I am planning on sourcing some appropriate bilstein's
  • TomDK
10 Jan 2017 18:35 #176524 by TomDK
What are your plans for the Jimny with this 3 or 4 link? It is just to see if it's possible or to do competitions?
  • OllieNZ
10 Jan 2017 20:13 #176538 by OllieNZ
TomDK wrote: What are your plans for the Jimny with this 3 or 4 link? It is just to see if it's possible or to do competitions?
No real plans, just doing what I can to optimise performance and handling with out comprimsing usability while I have it stripped down. More for the sake of it tbh but if I'm going to do it I may as well do it properly.
Time to create page: 0.103 seconds
