Grrr.. bumper fixings!!!
- Young Pretender
07 Jan 2017 21:20 - 07 Jan 2017 21:24 #176362
by Young Pretender
Grrr.. bumper fixings!!! was created by Young Pretender
These little buggers are stuck fast - lower black bumper section. Any ideas how I can remove the little blighters??
Have tried wire brushing, soaking in wd40, heat (stupidly because of plastic :blush: ) and also tried to drill one out but just killed a drill bit lol. Two of them one side are now impossible to get hold of with a screwdriver (one my fault and one already like that)
Last edit: 07 Jan 2017 21:24 by Young Pretender.
- Thank you received: 706
07 Jan 2017 22:10 #176364
Replied by jackonlyjack on topic Grrr.. bumper fixings!!!
Where it folds round and half moon shape is cut it with slitting disc then bend a little bit up to grab with pliers
Jack
Jack
- Young Pretender
07 Jan 2017 22:52 #176365
by Young Pretender
Replied by Young Pretender on topic Grrr.. bumper fixings!!!
I dont have a slitting disc sadly.
I wonder if I could hack saw the ends off then have another go with screwdriver?
Not sure about the two that I camt get at with a screwdriver any longer. Maybe another go with a smaller drill bit.
08 Jan 2017 00:45 #176367
Replied by Daniel30 on topic Grrr.. bumper fixings!!!
I used a good fit Phillips on the end of a ratchet came out easy with that
Good luck
Good luck
- mickt
08 Jan 2017 18:59 - 08 Jan 2017 19:00 #176401
by mickt
Replied by mickt on topic Grrr.. bumper fixings!!!
Correct size Phillips bit in socket with plenty of wd40 and plenty of slow turning with a good wallop of direct force centred on tip of bit. . Try tightening first and then alternate in / outs and oodles of patience..
Last edit: 08 Jan 2017 19:00 by mickt. Reason: amendment to the text
09 Jan 2017 07:56 #176412
by Busta
Replied by Busta on topic Grrr.. bumper fixings!!!
If the screw head is knackered you should have be able to drill it with a decent drill bit. Do it in stages so you don't generate enough heat to melt the plastic.
Time to create page: 0.116 seconds
