Heat shield protector needed - advice please?
29 Dec 2016 17:31 #176062 by jackonlyjack
maybe the rattle was there and just masked by the other rattle :unsure:
personally i would leave the exhaust till it becomes to loud or falls off ;)
Jack
  • susie
29 Dec 2016 17:35 #176063 by susie
Haha maybe you are right. I had new exhaust fitted 2 or 3 years ago. I just hate when the car makes sounds like that.
  • Daniel30
29 Dec 2016 20:33 #176078 by Daniel30
Could be just one of the rubber exhaust hangers gone?
  • susie
30 Dec 2016 01:16 #176084 by susie
I'm not sure. How could I find out. Where to look? Thank you
30 Dec 2016 09:08 #176088 by kirkynut
If you put the bottom of your foot gently on the tail pipe you can rock the exhaust slightly on its hangars to see if it's knocking on anything.
Vibrations are tricky to locate without getting under it with it running.
I would be careful spending too much on that car. It looks particularly rusty from what I can see in the pictures you've posted, albeit they don't show much of the underneath. If the tank guard is anything to go by I expect there's a great deal of welding required around the corner. It may not make economical sense to spend much on it now.
The chassis don't usually rot too badly on the Jimny. It's the body that rots. So the chassis rusting is another indication of it being a bit bad. I'm guessing though as I've not seen it. Just be careful not to get caught in that spiral of spending the car's value in repairs is what I'm getting at.
  • susie
30 Dec 2016 14:35 #176103 by susie
Yeah it is a pretty bad car and old. Just can't afford anything else right now.
I was told it was the silencer as the plates were rubbing together. Whatever that means?
Any idea if it's an expensive job to get silencer changed?
Thank you
Time to create page: 0.099 seconds
