Engine rebuild
- Paulig174
15 Dec 2016 22:16 #175702
by Paulig174
Engine rebuild was created by Paulig174
No eBay APP ID and/or Cert ID defined in Kunena configurationHi all.Im new to Bigjimny.com.I have a 99 jimny.Im rebuilding the engine after noticing water in the oil.The engine is out and I'm taking the head off tomorrow but I might try the oil pump first to see if it's mixing there.I ordered a rebuild kit from eBay and I'm worried about using it.It was very cheap.The link below is the kit I bought.Id appreciate advise. I would even bother using it if I had any doubts. Cheers
16 Dec 2016 06:47 #175704
by kirkynut
Replied by kirkynut on topic Engine rebuild
You'll only have a blown head gasket, no need for a full engine rebuild!
- Paulig174
16 Dec 2016 20:35 #175717
by Paulig174
Replied by Paulig174 on topic Engine rebuild
I know but I wanted to do a rebuild anyway and plan on doing a complete restoration job in undercarriage also and modify it for off road adventuring and possibly camping through Europe! I have the engine completely stripped and all internals removed.My problem now is I don't have socket to remove the head bolts.the are star shaped bolt heads
17 Dec 2016 10:16 - 17 Dec 2016 10:17 #175734
by facade
Replied by facade on topic Engine rebuild
If they are torx there are special sockets, but the splined ones undo with an ordinary 12 point socket of the correct size.
That rebuild kit looked good value, about what you would have expected to pay in The Olden Days, nowadays you won't buy the head gasket set for that.
(If it is Chinese, as I suspect I wouldn't use the pistons & rings
Last edit: 17 Dec 2016 10:17 by facade.
- Paulig174
17 Dec 2016 21:43 #175758
by Paulig174
It was 12 point splines.got them off with a 10 kingtony hex socet.It just got better.my block is cracked
- Paulig174
17 Dec 2016 21:48 #175759
by Paulig174
Time to create page: 0.220 seconds
