Nearside Half-shaft?
  • fozzie
08 Dec 2016 15:55 #175438 by fozzie
Nearside Half-shaft? was created by fozzie
Doe's anybody know where I might be able to buy a new or reconditioned rear nearside half-shaft?
08 Dec 2016 16:20 #175440 by j999pre
Replied by j999pre on topic Nearside Half-shaft?
You want just the shaft or shaft with abs bearing and backplate?
Grey pick up Jimny
  • fozzie
08 Dec 2016 16:38 #175441 by fozzie
Replied by fozzie on topic Nearside Half-shaft?
I think I need the shaft with abs ring and bearing etc.
My Jimny is going to my trusted indie on Monday. The garage he rents his space and ramp from is Coles Automotive. Alex Cole races Jimny's (believe it or not Paris Dakar has been mentioned) and has had the frustrating 'wom-wom' noise that drives me mad when the car reaches 45mph and above. He told my indie that his cars had similar noises that were cured by replacing the half shafts.
I'm just trying to find where I can buy new or reconditioned shafts incase one needs to be replaced.
  • fozzie
12 Dec 2016 16:33 #175581 by fozzie
Forget the half shaft!
My indie is struggling to find the cause of the 'wom - wom' sound that materialises over 45 mph. He has removed the rear prop shaft, put it into 4WD and road tested the car in front wheel drive only. The sound is still there, so it's not the rear diff or half shaft/wheel bearings as we originally suspected.
I can only surmise that the noise comes from the transfer box or gearbox. I did have the noise before the gearbox was repaired by the local Suzuki dealer, so I'm hoping that it's not the gearbox. I, like a lot of others don't trust what the 'stealers' do when it comes to warrantee work. It may well turn out to be a worn gear in the gearbox. The 'stealer' told me at the time that they replaced all of the bearings in the gearbox and the gears were okay and didn't need to be changed.
I think I'll wait till it breaks.
12 Dec 2016 16:41 #175583 by mlines
Replied by mlines on topic Re:Nearside Half-shaft?
The chain driven transfer box is known to make a woosh woosh sound?
Sent from my Nexus 6P using Tapatalk
