really loud vibration with slight judder
  • kelky7777
07 Dec 2016 02:30 #175365 by kelky7777
really loud vibration with slight judder was created by kelky7777
New to the forum so hi everyone.
This is my second Jimny, the first was a 2001
standard, 139k, and it had the same problem, vibration
but nothing like as bad as my new one. Now have a 2002
jimny on 104k, also standard, and as you can see in
the video I have really bad and loud vibration
changing through the gears. It had a new clutch fitted
before I bought it, and a new exhaust front section
and cat, also had a new gearbox mount. I've replaced
all the transmission oils, apparently the front diff
was almost empty, have checked and there are no leaks
since the fluid change.
The transmission also has a loud whine and a kind of
woo woo woo noise in all gears, from looking around
the forums regarding the vibration there are a few
comments suggesting that its normal but my last jimny
was nothing like as bad, I haven't been selecting 4wd,
don't think that's working as I get the flashing light
and with front jacked up the wheels are free spinning
even when in 4wd with engine running, I'll get around
to that problem later. So all driving has been in 2wd.
Any one know what could be causing this? My mechanic
drove the car and said he'd come across this with
transit vans and it was usually a bearing in the rear
diff, he checked the shaft linkages and said they were
fine though not sure how well he checked, I'll have a
look myself tomorrow.
  • johna
07 Dec 2016 08:27 #175372 by johna
Replied by johna on topic really loud vibration with slight judder
I would say its in the front end, there is a problem with 4wd, fix that first, as its probably there.When the hubs get water in them they rust and every thing sticks, you could have one wheel locked and the other free.and if the drive shafts get bent then there is the vibration.
John
  • kelky7777
07 Dec 2016 09:03 #175376 by kelky7777
Replied by kelky7777 on topic really loud vibration with slight judder
Hi John, cheers, I didn't think of that approach, I guess even if fixing the 4wd doesn't solve the vibration issue it's one job out of the way.
  • ryank192
07 Dec 2016 19:10 #175396 by ryank192
Replied by ryank192 on topic really loud vibration with slight judder
I have the exactly the same problem its really annoying. The only way i can deal with it is by keeping the Rpm high. :(
  • kelky7777
07 Dec 2016 19:25 #175402 by kelky7777
' I have the exactly the same problem its really annoying. The only way i can deal with it is by keeping the Rpm high. :( '
That's how I've been driving mine, problem is I end up driving in 2nd gear a lot. Have you tried any fixes yet?
  • ryank192
07 Dec 2016 19:53 #175408 by ryank192
I haven't tried anything yet. Been keeping an eye out on here to see if anyone had the same problem.
