Whine from rear diff
16 Dec 2016 14:36 - 16 Dec 2016 14:37 #175712
by Bosanek
Replied by Bosanek on topic Whine from rear diff
There is one self-thought-of trick which I am contemplating on trying:
1. Turn the vehicle on and put it into 4WD mode.
2. Turn the vehicle off.
3. Remove the transferbox-to-reardiff propeller shaft.
After that, when you turn the vehicle on, it should be a front wheel drive vehicle!
Now drive the car around and listen for the same noises or vibrations. Beware that the car might behave quite differently on road as a FWD vehicle.
This way you should at least be able to determine if the vibrations are caused by the removed propeller shaft or (to a certain extent) by the rear differential, or by something in or around transferbox or gearbox.
The problem with the diff diagnosis is, although it is now not driven by the propeller shaft anymore, the rear halfaxles are still turning parts of it..
What do others think of this idea?
Last edit: 16 Dec 2016 14:37 by Bosanek. Reason: typos
- fozzie
16 Dec 2016 17:27 - 16 Dec 2016 17:28 #175714
by fozzie
Replied by fozzie on topic Whine from rear diff
Hi Bosanek
My indie did take the prop-shaft off and ran it in front wheel drive. The noise was still there, so we suspect the gearbox.
Administrators.
I see my earlier reply stating that I'd done this has been removed, along with Martin's reply.
What did I do wrong?
Administrators.
Last edit: 16 Dec 2016 17:28 by fozzie. Reason: I'm illiterate!
- ZookFastback
17 Dec 2016 06:30 #175720
by ZookFastback
Replied by ZookFastback on topic Whine from rear diff
Squirt a tube of Nulon G70 (or the UK Equivalent) into the Diff and see if that fixes the noise. It is one of those Teflon-type additives that has worked for me in the past and is, at least, a cheap fix if it works and not a biggy if it doesn't. I've found it effective and add it to all diffs, gearboxes at service time.
17 Dec 2016 07:26 - 17 Dec 2016 07:31 #175726
by facade
Quite a lot of posts seem to have gone missing, some threads don't make sense as they refer to posts that have disappeared.
Anyway.
Mine had a whine from the rear axle.
Definitely the rear axle. :S
Even got one of those mek-a-niks to sit in the back and confirm that it was the rear diff, but not to worry, they whine for years.
Swapped out the diff, and still there.
Found massive play and notchiness in the rear wheel bearings.
changed them, the play and notchiness is still there (well there will be with a single row ball race and a 4 pin diff), and so is the noise.:evil:
Eventually, the brakes need 2 or 3 pumps to work, so I had a look at the front and changed the collapsed front wheelbearing.
And the whine from the rear diff had gone. :pinch:
What I should have done I suppose is jack the back wheels off the floor securely, and "drive" the thing at 40 and risk death by crawling round with a sounding stick listening for bearing noise. I wouldn't have heard anything though as it was the front, but it might have saved a diff and wheel bearing change.
Replied by facade on topic Whine from rear diff
fozzie wrote: Hi Bosanek
Anyway.
Last edit: 17 Dec 2016 07:31 by facade.
- ZookFastback
17 Dec 2016 07:32 #175728
by ZookFastback
Yea, the old Front wheel bearing ventriloquist problem, throwing its' whine to the rear
Time to create page: 0.098 seconds
