rear diff to front?
- panosd
30 Nov 2016 13:53 #175113
by panosd
rear diff to front? was created by panosd
Hello, i am thinking of installing a rear complete diff (with casing) to the front of my jimny.
I have vvt diffs and i think they are the casing of front and rear is he same.
Has anyone test it?
If this can be done i will then fit also a rear arb locker at front with trail gear hd shafts and cv's.
Has anyone test it?
- X8GGY
02 Dec 2016 11:47 #175171
Replied by X8GGY on topic rear diff to front?
They are different sizes aren't they?
- Thank you received: 115
02 Dec 2016 14:11 #175178
by maverick
Jalapeño, IISY?
Replied by maverick on topic rear diff to front?
Surely this WILL NOT work as the rer axle has different shafts to the front (aka CV's) and I thought the Diff itself was different.
Brakes will probably be different too, as will be shocker mounts ... surely they are a whole lot different???
Brett
Brett
Jalapeño, IISY?
- panosd
02 Dec 2016 15:25 #175180
by panosd
Replied by panosd on topic rear diff to front?
Maveric i dont want to mod the rear axle to fit at front.
I want to fit the rear diff only (3rd member) to the front axle case.
I think that the vvt's diffs have different size- design from the older jimny one.
I can't at the moment strip down both axles and try it, so i wondered if anyone had tried it, or has diffs down to check it.
In samurai's for example you can fit rear diff at front. It matches perfect. A friend of mine tried it and now has 2 rear arbs's on
and HD axle shafts and cv's.( already from the diff swap 26spline at front).
Also the rear diff is stiffer than the front one.
02 Dec 2016 17:55 #175187
by facade
Replied by facade on topic rear diff to front?
You will have to try it.
On a pre-vvt, the drive flange is low on the front diff, and central on the rear, this might not matter with a lift, and the front halfshafts won't go in a rear diff.
No idea about a VVT.
02 Dec 2016 19:51 #175192
Replied by Riccy on topic rear diff to front?
why bother? the arb diff kit for the front is near enough the same price as the rear?
Time to create page: 0.103 seconds
