Screeching alternator belts
- mattsccm
29 Nov 2016 20:24 #175094
by mattsccm
Screeching alternator belts was created by mattsccm
Mine is driving me to distraction. It does this every winter. New belts last a few weeks. The pulley is fine and cleaned up nicely yet the slightest bit of damp or cold , say a misty morning, leaves the belt screeching until everything warms up. It occasionally does it if I slow suddenly but usually it can be stopped to some extent by dropping into neutral or even sometime knocking the lights off. After a few miles all is fine. If its howling, which I assume is slipping, when the lights are on there is a noticeable dim in the lights. No squealing = perfect lights. Belts are tight as they should be or maybe a gnats over. Alternator is fine. Even replaced belts look fine and are no where near normal renewal stae and don't wear unevenly or anything.
Is there some little trick that only Jjimny owners should know?
29 Nov 2016 22:52 #175099
by Busta
Replied by Busta on topic Screeching alternator belts
The alternator belt isn't tight enough. Make sure the 8mm allen key bolt at the bottom of the alternator is loose when you tension the belt. You will probably need to use a pry bar to get enough tension.
30 Nov 2016 06:32 #175101
by facade
The pulley on the crankshaft falls apart, and releases some of the tension on the alternator belt.
Then when you are happily trundling along the whole outside of the pulley falls off.
It is a design error that a three year old wouldn't make :pinch:
Section through crank pulley
Replied by facade on topic Screeching alternator belts
mattsccm wrote: Is there some little trick that only Jjimny owners should know?
30 Nov 2016 16:42 #175115
by Mike G
2" Trailmaster suspension lift, 2"body lift, snorkel, full breather kit, 29" steel wheels with BFG tyres, tinted rear windows, CRT CB radio with modulator antenna mounted on rear, dog cage and tray in the back.
Replied by Mike G on topic Screeching alternator belts
I have been plagued with belt noise for a while now too. A constant noise that sounds like grinding or air in the coolant pump. Turns out that it was the belt making the noise, because when I changed the water pump and cleaned off the pulley of old belt debris, the noise still occurred. It's only the water pump and crankshaft pulley that are in the equation for making the noise because if I spray silicon spray on that belt or those pulleys, it stops the noise, for a while. But it will eventually come back. The belt is on tight enough and all the bearings were fine as I checked them all when I replaced my radiator. Next time when I change my belts, I'll be sure to thoroughly inspect the crankshaft pulley. What would you be looking for on the crankshaft pulley and if it's gone, what do you need to replace, bearing, oil seal, pulley itself?
30 Nov 2016 19:00 #175125
by facade
I've no idea what to look for, mine looked totally fine (apart from major rust) until the day that it came apart, but in the final weeks I was getting a sort of groaning like a dry gearbox bearing when I pulled away and revved it in second (I tend to get the wheels turning in first, and do most of the brisk acceleration in second).
To change it you just need the pulley, but I ended up with a pulley, a new bolt and a new oilseal as I had a major saga getting the pulley off
www.bigjimny.com/index.php/forum?view=to...9489&start=24#161470
- mickt
30 Nov 2016 19:06 #175129
by mickt
Replied by mickt on topic Screeching alternator belts
Its the rubber inbetween the inner and outer parts of the pulley that is there to dampen vibrations at certain revs on the M13 dual cam engine. It deteriorates but is not always physically visible as happened to my daughters car. It ate two belts, the second one lasted about one day. Replaced the pulley and its been as good as gold since.
Time to create page: 0.104 seconds
