Rear engine mount issue
- Damo666
29 Nov 2016 17:59 #175071
by Damo666
Rear engine mount issue was created by Damo666
Hi guys....haven't been on here a lot...as quite frankly my partners Jimny has been behaving and haven't needed any advice.......until now! Sorry.
ANYWAY....driving home from work last night my partner says she heard a loud metal noise...she describes a "kerdunk" as though she drove over something....bit further down the road engine management light comes on. Sounded lumpy on tick over when she got home too.
Panic stations now as I'm thinking big end/head gasket etc etc as it sounded like a misfire!
Nothing to read code so I took battery off and put back on and light went out....came on again after short drive and has since gone out again.
Engine sounds fine when revved but still lumpy looking tick over and engine has a real wobble in engine bay when revved....as does the gear stick in cabin....like I've never seen before!!
I got under car and was able to lift gear box with my hand from mount so it's safe to say this is knackered!
Is it plausible that the engine jumping about could have pulled a sensor lead and caused engine management light?? Because it's off again now! I noticed a wire going to the sensor by the cat was pretty taught....could that have caused it and now it's OK again but seems lumpy because engine loose?
Sorry for long post but didn't know how else to put it??
Your help is appreciated!
Sent from my SM-A500FU using Tapatalk
- Damo666
29 Nov 2016 18:00 #175072
by Damo666
Replied by Damo666 on topic Re:Rear engine mount issue
Sorry it's a 2003 Jimny
- mickt
30 Nov 2016 19:11 #175130
by mickt
Replied by mickt on topic Re:Rear engine mount issue
I would say yes it is possible. First job is to replace the mount. They sell them in the shop or can be had on line. The one I got on line comes without anchor nuts but two nyloc nuts does the job. Job is fiddly but straightforward. Need a jack to lift the box though.
- X8GGY
02 Dec 2016 11:44 - 02 Dec 2016 11:45 #175170
Replied by X8GGY on topic Re:Rear engine mount issue
Last edit: 02 Dec 2016 11:45 by X8GGY.
02 Dec 2016 20:31 #175195
by facade
Replied by facade on topic Re:Rear engine mount issue
Mine went the same, and the holes were miles out, so I slackened the front engine mounts and moved the engine until I could lift the gearbox slightly and drop it, and the holes lined up.
I was thinking the misalignment was straining the mount and made it break.
- Damo666
02 Dec 2016 23:44 #175202
by Damo666
Thanks for the response guys. Managed to get a mount from Suzuki next day so I've now got it ready to fit tomorrow. Will let you know how I get on. I might try and do a how to video as there's nothing on it that I could find! I did one for the reverse light sensor before as no one had done one......
Time to create page: 0.103 seconds
