Having trouble with mini lobster conversion!!!
  • BlueMudMonster
24 Nov 2016 02:04 #174860 by BlueMudMonster
Having trouble with mini lobster conversion!!! was created by BlueMudMonster
So I have the 410 box mounted in place, all props sorted and bolted up but need advice....
1. Bought poly bushed mounts for the transfer box but when I tighten them the two bushes between the mount of the chassis and the mount of the cradle collapse on themselves. Is this supposed to happen?
2. The top of the transfer box seems to be very close to the body (this could be because I haven't tightened the mounts enough?) and it sounds like there knocking against eachother when changing gear.. Do I tighten the bejasus out of the mounts to pull it away from the body and just let the bushes collapse on themselves?
3. Theres two block connectors in the standard Jimny t/box. One that goes to the speed sensor and an other white one. What is the white block connector for and does it have a place in the 410 t/box?
Any help much appreciated!
  • wilku
24 Nov 2016 07:06 #174862 by wilku
Ad. 3. If I understand your question correctly the white connector goes to the 4WD controller module. It sends a signal when 4wd is engaged/disengaged and the controller operates the vacuum system. It also lights up the 4wd light on the dashboard (via the 4wd module, but that is easily hacked if you have manual huns)
Time to create page: 0.086 seconds
