grinding noise front axle
- dylanaicsremi
21 Nov 2016 11:12 #174770
by dylanaicsremi
grinding noise front axle was created by dylanaicsremi
Hi
every so often their is a grinding noise coming from my front axle when in 2wd?
not sure if it still does it in 4wd, it sounds like a driveshaft is away but i thought nothing in the front axle moves when in 2wd so rather confused?
any help thanks
any help thanks
- dylanaicsremi
21 Nov 2016 11:52 #174772
by dylanaicsremi
Replied by dylanaicsremi on topic grinding noise front axle
is it worth doing transfer/gearbox/diff oil change?
21 Nov 2016 19:05 #174778
Replied by Riccy on topic grinding noise front axle
vac hubs sticking in? if they are stuck in then they will make the half shafts turn, which could make noise from the front axle
- Thank you received: 706
21 Nov 2016 22:47 #174792
Replied by jackonlyjack on topic grinding noise front axle
always worth changing oil's
also noise could be from brake backing plate rubbing against the disc
Jack
Jack
- Georgieboy83
22 Nov 2016 07:02 #174795
by Georgieboy83
Replied by Georgieboy83 on topic grinding noise front axle
Sounds similar to my issue, almost sounds like a wheel bearing has gone but comes and goes and disappears in 4x4 so can't be wheel bearing. I have been told it's possibly the rubbers on the property sharf? Not sure about this though. I had the noise on and off for a few weeks then disappeared for a few weeks.
- dylanaicsremi
25 Nov 2016 10:07 #174897
by dylanaicsremi
changed oils in diffs noise seems to of disappeared for the time being
fresh oil is always a good idea!
Thanks
Thanks
Time to create page: 0.099 seconds
