Alternator belt
- Georgieboy83
20 Nov 2016 16:11 #174749
by Georgieboy83
Alternator belt was created by Georgieboy83
Alternator belt snapped yesterday after making a noise like it was slipping.mechanic Replaced belt today and sounded fine but driving home making a sliping noise again but only when i rev as soon as the engine is ideal it goes. Doesn't seem to make the noise when i first start travelling but after a few minutes it starts again. It sounds like it may be coming from the alternator. Do these symptoms sound familiar to anyone?
- mickt
20 Nov 2016 16:37 - 20 Nov 2016 16:39 #174751
by mickt
Replied by mickt on topic Alternator belt
What engine have you got? There are a number of threads about the problem on the M13a 1328cc engine lower pulley delaminating and the only option is to replace it. The shop sells them.
Last edit: 20 Nov 2016 16:39 by mickt. Reason: amendment to the text
- Georgieboy83
20 Nov 2016 16:59 #174752
by Georgieboy83
Replied by Georgieboy83 on topic Alternator belt
Not sure about engine sorry, it's an 04 plate jimny mode. When the belt snapped yesterday all the rubber dust was collecting on the lower pully. What sort of cost would i be looking at to repair this do you think ? Thanks for your reply it's very much appreciated
- mickt
20 Nov 2016 17:18 #174753
by mickt
Have you got the log book? If so the engine details are in there. Under the bonnet if it is a m13a it will be a dual cam engine and have that wrote on the top black cover. The crankshaft pulley has a rubber insert between the inner and outer rims and is there as a damping medium. Although it might look OK these start to breakdown and cause the pulley to distort hence the noise and the belt s breaking. Look in the shop at the top of the forum for the price of the pulley.
- Georgieboy83
20 Nov 2016 17:52 #174754
by Georgieboy83
Unfortunately i still waiting for log book to come back. I have been out for a look under the bonnet but couldn't find a number like that. Thanks for the information you have given me.
- Georgieboy83
20 Nov 2016 18:08 #174755
by Georgieboy83
The noise definitely seems to be coming from the pulley on the alternator would this be the issue you mentioned above?
Time to create page: 0.098 seconds
