4WD controller module & manual hubs
  • wilku
14 Nov 2016 19:13 - 14 Nov 2016 19:15 #174635 by wilku
So, my vacuum hubs stopped disengaging and I decided to replace them with the manual ones. I did that without a problem and now I'm thinking on removing the unnecessary stuff that remains after the swap. So I removed the vacuum valves and some of the tubes and now I need to sort out the electronic / electric stuff, and:
I want to remove the 4wd controller module completely, and connect the blue/blk cable from 4wd switch with the blue cable for 4wd light which will solve the blinking light problem. However I've noticed two things:
1. There's a cable from 4wd module to the ECM and it outputs (or maybe receives???) variable voltage depending on engine speed - is this data used in any way by the ECM? Has anyone removed this module? Did it cause any errors?
2. The service manual on page 3D-10 shows a table of voltages on the 4wd module coupler and it says that when 4wd is on there is 0V going to the indicator lamp and 11-14V when the transfer is set to 2wd. Is it a mistake? Or am I too dumb to understand the basic circuit logic here? Actually IMHO the voltages are wrong for every set of 2wd/4wd transfer setting - I must be missing something... Any help?
Last edit: 14 Nov 2016 19:15 by wilku.
  • EricTheRed
15 Nov 2016 21:08 #174673 by EricTheRed
Replied by EricTheRed on topic 4WD controller module & manual hubs
Re Question 2:
In 2wd the bulb has a positive feed but its "control switch" ,probably some sort of open collector transistor/fet in the controller will be
"off" (open circuit).
So when the voltage is tested with reference to negative (body) it will show the battery voltage minus the voltdrop across the lamp
its self in series with the volt meter internal resistance. This will be as stated in the manual..
Re Question 1:
Not sure about this , but a guess would be that it's a voltage divided output from the ECU and read via a A2D converter in the 4wd unit , to ensure the engine is running and of sufficient speed for the vac system to try to operate correctly.
Time to create page: 0.071 seconds
