Engine shaking on tick over
- Durham Jimny
12 Nov 2016 15:15 #174543
by Durham Jimny
Engine shaking on tick over was created by Durham Jimny
I have a 1998 Jimny auto with a G13BB engine. Recently I noticed a loss of power and on investigation realised I have no water in the expansion tank but a load more white creamy oil in the rocker cover !
Hence I have been renewing the cylinder head and gaskets.
I am not a mechanic but thought I have done a pretty good job and the engine restarts.
However it starts to shake and has erratic revs. When out on the road it sometimes is short on power and when warm will not tick over and cuts out unless the throttle is held slightly. This is made worse by it being an auto and driving is difficult as it cuts out at every junction but restarts straight away.
I have renewed the spark plugs and checked all the leads etc.
After reading some post on hear I have changed the Lambda sensor but it has made no difference.
I would hope it is not the valve clearances or timing etc as there is no engine knocking etc and it starts on the button.
I see a lot of posts point to the Cam Position Sensor and I will probably try this next.
The engine warning light does not come on and I do not think this model as the OBDII port thing.
Has anyone had a similar problem or have any suggestions please.
Thanks
Thanks
- jim
12 Nov 2016 18:09 #174547
by jim
Replied by jim on topic Engine shaking on tick over
Well done for sorting out the HG. I experienced power loss and rough idling recently. I narrowed it down to the cam or crankshaft sensors , blocked catalytic converter or ignition coils. It was the ignition coils.
- Thank you received: 706
12 Nov 2016 18:35 #174549
Replied by jackonlyjack on topic Engine shaking on tick over
how's the pressure coming out the exhaust
if it feels really weak and very hot
it could be blocked cat or collapsed silencer
building to much back pressure could cause your symptoms
Jack
Jack
- mickt
12 Nov 2016 18:40 #174550
by mickt
Replied by mickt on topic Engine shaking on tick over
Recheck the timing would be my first call. One tooth out possibly.
- Durham Jimny
13 Nov 2016 09:07 #174565
by Durham Jimny
Replied by Durham Jimny on topic Engine shaking on tick over
Thanks Jim. I do not think I have a crankshaft sensor on this model but have ordered a new Cam sensor to try. I never considered a blocked Cat or the ignition coils. I will try the sensor first and see what happens.
- Durham Jimny
13 Nov 2016 09:09 #174566
by Durham Jimny
Thanks Jack
I have tried the exhaust and it seems the same as it always did at the end. It was a new full system about 6 months ago so I hope it is not that.
Time to create page: 0.098 seconds
