Altonator issues
- RD15
11 Nov 2016 18:22 #174520
by RD15
Replied by RD15 on topic Altonator issues
The belts on it are new, probably less than 5 miles use so hopefully ok, I might put a new aux belt tensioner on it at the same time though
- RD15
11 Dec 2016 12:36 #175531
by RD15
Back to this, tried to cheat it for a bit by just cracking the tension up on the altonator, worked for a few weeks but it's ripped the belt again, going to drop radiator, swap out crankshaft pulley, clean up all pulleys really good and put on new belts, and then pray
- mickt
11 Dec 2016 19:29 #175551
by mickt
Replied by mickt on topic Altonator issues
Good call!
- RD15
13 Dec 2016 22:15 #175620
by RD15
Right, did as above and swapped old pulley out, im going to briefly explain how we did this as the crankshaft bolt was very tight, we wedged a thick screwdriver though one of the pulley holes and against the bottom of the engine, then used a breaker bar with a 2ft extension on and pulled it the regular "Leftie loosey" (counter clockwise) and after snapping one breaker bar we did it.
The old pulley then just slid off, the outer metal is connected to the inner with a small rubber Cush and this appeard to have become disjointed at one side and you could push the inner section away from the outer by a good amount.
Everything back in place now and started her up, put as much load onto the altonator as I dared (high beams, radio, heater ect) and I couldn't fault it, not one squeek
If you don't hear from me again this was what has cracked it! And Thankyou for the advice
- mickt
14 Dec 2016 19:35 - 14 Dec 2016 19:39 #175654
by mickt
One of the members did post a thread on how to make a tool that mounts on the pulley with two bolts and locks the pulley. I got my bolt free with a impact wrench but I still made a copy of his and it works. The ALTERNATOR on the M13 is prone to this problem and overtightening the belts does no good but actually causes more damage. The pulleys are not cheap but keep buying belts with the possibility of a severe overheat plus breakdown is not an option in my book.
The members avatar is "façade" and his entry is dated 28 Jan. Doing a search of pulley tool" will find it.
Last edit: 14 Dec 2016 19:39 by mickt.
15 Dec 2016 08:03 #175668
by facade
Replied by facade on topic Altonator issues
It was me.
www.bigjimny.com/index.php/forum?view=to...=7&id=59489&start=24
I had a lovely time undoing the bolt, which had welded itself to the pulley with rust, on the page before I showed how I undid it with my fingers, after cutting away the flange on the bolt :ohmy:
