left wingmirror
  • Decklandpt
02 Nov 2016 17:43 #174163 by Decklandpt
Replied by Decklandpt on topic left wingmirror
you can keep the spiders, they are the only thing that gives this manly man the shivers...that and freshly cut fingernails on syntetic fabrics lol.
if you could, please send it via the extra fast special delivery thingy, dont want it getting lost in the post office lol
again, thank you so much.
03 Nov 2016 16:07 #174205 by jackonlyjack
Replied by jackonlyjack on topic left wingmirror
Decklandpt wrote: you can keep the spiders, they are the only thing that gives this manly man the shivers...that and freshly cut fingernails on syntetic fabrics lol.
price sent by PM
Jack
  • helijohn
03 Nov 2016 18:35 #174220 by helijohn
Replied by helijohn on topic left wingmirror
Decklandpt wrote: hi there.
2000 suzuki jimny
My left wing mirror is currently dangling in the wind.
I may have misunderstood but I removed the mechanism from behind the driver's mirror and secured the glass in place with cable ties from behind. It was still possible to adjust the mirror (glass) by hand.
  • Decklandpt
03 Nov 2016 19:21 #174227 by Decklandpt
you did somewhat...or i did..
what's gone is the "grab" on the pivot.
the base of the mirror as a vertical "spike", that goes up the mirror casing. once inside, a spring is placed around it, and then held in place by a castle nut. like a washer, with "teeth" on the inside edge. those "teeth" form a hole smaller than the spike, so that washer is pressed down onto it and the "teeth" hold it in place. that's the part that came of. so the whole assembly is flaying in the wind.
i tried to remove the glass part, didn't come off, and having no replacement at hand, didnt want to risk not being able to put it back in place, leaving me with no mirror whatsoever.
one would need to get a tool, maybe a couple of c-clamps (since the wires for the motor go up tru the spike and castle nut) to push down the castle nut. that is not possible, not without some inventiveness at least, because the spike and castle nut are surrounded by a plastic hood...almost as if the spike and nut was inside a pipe.
if it was just the mirror itself, no problem, just pop something in place and call it a day.
what really pisses me off is knowing that nothing is actually broken, it's just the design of the thing that makes it so hard inf not impossible to fix.
plus...almost 300€ for a new one... that's stupid money...was about to weld some plates over the holes and switch both mirrors for the samurai ones, for 22€ a pair
Time to create page: 0.082 seconds
