Diff lockers
  • Venter
30 Oct 2016 10:32 #174052 by Venter
Replied by Venter on topic Diff lockers
I was really pretty sceptical of the 1st post of yours above, Rich. But the way you explained it further along, it actually sounds like a pretty decent idea given that you'll have unlockable rear hubs.
The big unknown now is how a Jimny behaves on the road as a purely front-wheel drive. But given that there'll be more weight over the drive wheels, you may well see an improvement in road manners as the back end won't be as skittish through roundabouts etc.
If things don't quite work out though, agreed with TomDK that Arb lockers are much cheaper on the continent, even with the changed £/Euro exchange rate, so don't bother with UK vendors regarding them.
30 Oct 2016 10:34 #174053 by Keithy
Replied by Keithy on topic Diff lockers
Rich wrote: When the spool is fitted and run in front wheel drive with the freewheeling hubs selected the shafts will still turn but the freewheeling hubs will work exactly the same as they do on the front so will not give any drive and should corner same as a front wheel drive car.
Now that'll work fine!
I thought of making the diff locks for mine but dropped lucky with the cash/no vat at the time I got my ARB set......it's expensive to connect one shaft to another it seems!!
  • TomDK
30 Oct 2016 18:17 #174065 by TomDK
Replied by TomDK on topic Diff lockers
Have a look here www.hm4x4.com/HM4X4Shop/index.php?cPath=179_182_203
There are other cheaper places, just use google. Search for ARB RD206, RD207, RD208.
30 Oct 2016 18:34 #174066 by Busta
Replied by Busta on topic Diff lockers
By all accounts, I can't see a fully locked diff being any more of an issue than driving with a lockright. At least with a spool you know it's locked all the time. None of this coasting into corners then carefully applying power hoping it won't lock mid corner business.
Unlocking one rear hub and using 2wd will be safe on the road, albeit with reduce traction.
And you can't complain at the price.
30 Oct 2016 18:54 #174067 by Keithy
No eBay APP ID and/or Cert ID defined in Kunena configurationLooks cheap.....Italy is a long way to mail a faulty unit back.... Ebay has a knockoff
  • TomDK
30 Oct 2016 19:42 #174071 by TomDK
For that kind of money you can get a genuine arb locker locker. Almost £700 for an inferior Chinese copy..
Time to create page: 0.095 seconds
