Towbar advice request
  • Tony L
21 Oct 2016 09:17 #173777 by Tony L
Towbar advice request was created by Tony L
Hello all,
I'm planning to sell my small motorhome and use my little used 2008 Jimny for towing a Going Go-Pod, which I have ordered. Can anyone out there point me in some direction regarding a decent DIY towbar? Can the electrics (13 pin) be ''plumbed'' directly into the existing Jimny wiring? Where is the best place to find the cables at the back of the Jimny? Any advice, no matter how small or simple, would be much appreciated :)
Kind regards,
Tony L
  • GRAYWOLF
21 Oct 2016 10:27 #173778 by GRAYWOLF
Replied by GRAYWOLF on topic Towbar advice request
Hiya, i fitted one recently, cost me £119.00 complete with electrics, i opted for the removeable ball type, neater when not in use..electrics are simple .. really, in rear left panel on mine, took about half hour to wire in with kit supplied.. bought of ebay from trader.. very good value, not bad to fit, if you follow instructions.. useful accessory..
  • X8GGY
21 Oct 2016 10:42 #173780 by X8GGY
Replied by X8GGY on topic Towbar advice request
One I fitted to mine, blog may help give you an idea - www.bits4vits.co.uk/store/fitting-a-tow-...-jimny/blog_249.html
B)
  • johna
21 Oct 2016 19:50 #173793 by johna
Replied by johna on topic Towbar advice request
Built my own, not hard to do if you can weld.it doesn’t have to be a ton of steel remember they only have a small towing capacity.as said electrics can be picked up behind the rear plastic panel on the passenger side. easy to get off.
21 Oct 2016 21:08 #173795 by Lambert
Replied by Lambert on topic Towbar advice request
Be aware that all towing equipment in the UK has to be type approved and meet relevant safety standards. Also with 13pin electrics they are tested as part of the mot and have to work correctly in the same way as the bar has to be suitably firmly attached. 7 pin electrics are only visually inspected and are not required to actually work.
22 Oct 2016 06:16 #173800 by skywalker65
Replied by skywalker65 on topic Towbar advice request
Bought a Tow Trust one off the Bay with the ball and pin hitch.
Bought the genuine Suzuki kit for 13pin electrics from my local dealer. Doddle to fit and was plug and play
If in doubt ...... Flat out ??
Time to create page: 0.108 seconds
