Abs light on all the time, how do I read codes?
  • NineCherries
16 Oct 2016 22:11 #173639 by NineCherries
I'm having a run of bad luck with my Jimny just now, crankshaft pulley gave up the ghost at the start of the month (all fixed now). But now the abs light is on.
The abs light came on last Thursday but turning the car off and on again cleared it, not been out in the car till this afternoon (Sunday) and the lights on all the time.
Is there anyway to read codes? No brake/wheel work has been carried out recently, so I'm looking for advice on where to start looking. I did notice the lack of the hummmmmm noise I usually get as I drive up the street for a few seconds (I presume it's from the abs pump as you get the same noise when the abs kicks in on snow/ice etc)
I did search the site but most people have had faults after doing work in the car, bearings etc so had a reference point to start looking. I also read something about dtc? but not sure if that plug only relates to older Jimny's
For info mine is a 2008 model.
Thanks in advance folks.
16 Oct 2016 23:01 #173645 by Keithy
Have a look and see if a sensor has a lot of rust on it (I'm assuming they are VR sensors) lines of gauss may be nullified?
possibly someone with a working abs system could measure the resistance at the sensor for you to narrow the issue down.
The following user(s) said Thank You: NineCherries
  • NineCherries
17 Oct 2016 07:58 #173651 by NineCherries
Replied by NineCherries on topic Re:Abs light on all the time, how do I read codes?
Little update.
Light didn't extinguish when I started the car this morning but whilst reversing out the drive way it went out?? Hmmm temperamental faults. :(
17 Oct 2016 13:24 #173661 by Keithy
NineCherries wrote: Little update.
Bloody cars! ::dry::
Time to create page: 0.078 seconds
