steering arm
10 years 1 month ago #173476 by jackonlyjack
steering arm was created by jackonlyjack
any easy way to remove the steering arm from steering box/column splines
thanks
Jack
  • X8GGY
10 years 1 month ago #173480 by X8GGY
Replied by X8GGY on topic steering arm
A puller -
... but expect a fight! :evil:
I ended up cutting mine off in the end! :(
10 years 1 month ago #173481 by jackonlyjack
Replied by jackonlyjack on topic steering arm
S200KYS wrote: A puller -
not the pitman Dave i need to extend the shaft for body lift ;)
Jack
  • X8GGY
10 years 1 month ago - 10 years 1 month ago #173483 by X8GGY
jackonlyjack wrote: ...not the pitman Dave i need to extend the shaft for body lift ;)
Jack
Ah, sorry, mis-understood...
Try this blog then - www.bits4vits.co.uk/store/daily-driver-jimny/blog_340.html
Just over half way down at the 29/04/16
Dave ;)
Last edit: 10 years 1 month ago by X8GGY.
10 years 1 month ago #173484 by jackonlyjack
thanks for the link Dave
but i can't slide the thing off the splines :(
Jack
  • X8GGY
10 years 1 month ago #173485 by X8GGY
Take both the pinch bolts out that go beside the splined bits of the shaft, and then jack the body up... ;)
Once the body is lifted up you'll be able to lever the steering shaft off the splines and get it on the bench to fit the spacers in...
Dave
Time to create page: 0.113 seconds
