Squealing Like a Pig!
- Venter
12 Oct 2016 16:13 #173441
by Venter
Squealing Like a Pig! was created by Venter
Had a squeal for almost a year now. First result was shredded belts last winter, which got replaced.
After belt replacement, squeal came back, different in sound/pitch though. Thought it might be crankshaft pulley, but then decided that it was clutch-release bearing, because it seemed to be coming from rear of engine bay, but I haven't been able to confirm its location, so might be wrong.
Now I've just installed new clutch kit and whaddaya know, squeal is still there!
Squeal is (almost) never there when stationary, mainly kicks in when accelerating or engine braking. It gains volume the longer I leave it, but I can get rid of it completely (for a short while) by flicking the key in the ignition off and on again quickly. Mainly there in 1st, 2nd, 3rd gears, seldom in 4th, and never in 5th.
Anyone have ideas?
Anyone have ideas?
- mickt
12 Oct 2016 18:33 #173446
by mickt
Replied by mickt on topic Squealing Like a Pig!
What model have you got regarding engine and box?
- Venter
12 Oct 2016 20:37 #173455
by Venter
Replied by Venter on topic Squealing Like a Pig!
2003 (M13A).
Transfer box and everything else is standard.
Got 101k miles
Got 101k miles
- Thank you received: 2004
13 Oct 2016 05:49 #173459
Replied by Lambert on topic Squealing Like a Pig!
Have you checked all the bearings on all the ancillary rotating components with a stethoscope eg water pump, power steering, belt tensioner etc?
13 Oct 2016 05:53 #173460
Oh and have you looked for witness marks on things like exhaust heat shields they can sometimes be more of a squeak than a rattle?
- johna
13 Oct 2016 07:44 #173463
by johna
Replied by johna on topic Squealing Like a Pig!
same year same engine and i have noticed a slight squeal when fast accelerating in 1,2,3 gears.not loud but its there,so i will follow your endeavour, its not loud enough to worry me at the moment. so when you find the culprit please post it here.
john
john
