Nitrogen in tyres
  • stuartmc
11 Oct 2016 16:26 #173376 by stuartmc
Nitrogen in tyres was created by stuartmc
Just had my Jimny Serviced and MOTed for the first time since I got it. There was a comment on it that they couldn't check the tyre pressure as it had green valve caps which meant they were filled with Nitrogen. Hadn't even noticed that they had green valve caps so not very observant.
One of the rears looks like it could do with a top up so not sure what I need to do. Is this standard fitting/filling, can I use ordinary air to top up or do I need to find someone that can top up with Nitrogen and how easy is this to find? Lastly what is the reason for using Nitrogen in the first place?
  • 1066Boy
11 Oct 2016 16:39 #173377 by 1066Boy
Replied by 1066Boy on topic Nitrogen in tyres
Just top up with air. This whole nitrogen craze is completely pointless on normal cars.
11 Oct 2016 16:57 #173379 by facade
Replied by facade on topic Nitrogen in tyres
stuartmc wrote: Lastly what is the reason for using Nitrogen in the first place?
Cynically, so they can charge you a squillion pounds extra when they fit them, rather than use compressed air which is free.
There are volumes of opinions about this,
they reckon that oxygen molecules are smaller than nitrogen molecules (despite the higher molecular weight) and can diffuse out of the tyre quicker, so nitrogen keeps the pressure for longer
they say as there is no oxygen inside the tyre, the inner surface doesn't deteriorate as quickly (leading to more porosity and faster leakage)
The pressure stays constant- this one patently isn't true as all gases expand when they are heated. However, pukka race cars use nitrogen cylinders rather than an airline to inflate tyres because the nitrogen is dry, and the moisture in the air will cause big pressure changes as the tyre warms up.
If you believe that this will make a noticeable difference on a Jimny then can I interest you in buying a bridge??? :)
11 Oct 2016 18:00 #173383 by Keithy
Replied by Keithy on topic Nitrogen in tyres
Any guesses what the loon who went with N in the tyres is full of? :D
11 Oct 2016 18:06 #173385 by mlines
Replied by mlines on topic Nitrogen in tyres
I make sure I go for the 78% Nitrogen, 21% Oxygen mix (How to confuse a QuikFit Fitter)
11 Oct 2016 18:32 #173388 by Busta
Replied by Busta on topic Nitrogen in tyres
mlines wrote: I make sure I go for the 78% Nitrogen, 21% Oxygen mix (How to confuse a QuikFit Fitter)
:lol: with a hint of argon for good measure.
Time to create page: 0.104 seconds
