Vacuum hubs
  • Littleblue
10 years 1 month ago #173260 by Littleblue
Vacuum hubs was created by Littleblue
Hello all, I'm new to the forum. My jimny has recently developed a problem twice after just starting off it made a horrendous racket a grating banging noise . It seems to me there is a very small leak in the vacuum system and if the car is left for a few hours the 4 wd is partially engaging as I get a clunk shortly after setting off. I've got round this problem by shifting into 4wd just after starting engine and then popping it back into 2wd. Had a look at the pipe work whilst carrying out a service and can't see any splits( I expect it's a tiny hole as it takes hours to leak enough to cause the symptoms). My thoughts are to change the rubber hoses first and see if that's the issue before tackling the metal pipe work.
Does anyone know the bore of the rubber hose ?
Where they go to the hub is it just a push fit?
I know you can get manual hubs but I'd like too stick with the vacuum set up.
Thanks
10 years 1 month ago #173339 by Bosanek
Replied by Bosanek on topic Vacuum hubs
From your description of the issue, it appears to me that you believe that the vacuum has to be present for the entire duration of 4WD operation. Your entire approach to the issue is based on that assumption.
However, as far as I know, vacuum is applied to the wheel hub assembly only for a short amount of time (~10 seconds) when 4WD mode is engaging or disengaging. Vacuum is not needed to keep the hubs "locked" during 4WD operation.
In other words, when you are in 2WD and engage into 4WD, the vacuum gets applied for approx. 10 seconds to the hubs through one of the pipes. After cca 10 seconds, the application of vacuum stops. If the hubs manage to get locked during that time, 4WD controller senses that and proclaims that 4WD is now on. You can now stay and drive in 4WD indefinitely, without any need for the vacuum. I think that you could technically even disconnect the pipes from the wheels at that moment, and the hubs will still stay locked - vacuum does not keep them locked.
The vacuum will not be applied again until you press 2WD button. Then the vacuum will be applied for cca 10 seconds to the hubs through the other pipe (there are two pipes going to the each front wheel). This time, the vacuum will unlock the hubs.
Conclusion - if you successfully shift into 4WD (both hubs get locked, transfer case gets connected to the front prop shaft) and then turn the car off and leave it like that for any desired amount of time, the next time when you turn it on, the hubs should still be locked - because the vacuum is not needed to keep them locked.
I can not help you about the sounds which you are hearing, but I at least hope that this provides a new and correct direction for your investigation process.
Time to create page: 0.079 seconds
