tyre pressures ?
07 Oct 2016 21:30 #173252 by Me and my Jimny
Hi Guys
Went to the garage to top up a tyre which is a little low, but of course you have to set the required pressure that you want it to reach. I have no idea on these.
The tyres are Yokohama geolanders 225/75r16, can anyone help ?
Cheers
Paul
08 Oct 2016 05:39 #173262 by Lambert
Replied by Lambert on topic tyre pressures ?
You can work it out mathematically the information about load and pressure is.on the side of the tyre and the.axle weights are on the vin plate. I would however start of with the factory 23psi front and 26psi back to see how it behaves.
09 Oct 2016 08:21 #173287 by Me and my Jimny
Replied by Me and my Jimny on topic tyre pressures ?
Thanks, I thought it would be higher with a bigger tyre, 23 still seemed a little low at the front so I put them all to 26. Seemed good on the road so I'll see how it later when we go for a play
  • 1066Boy
09 Oct 2016 08:41 #173290 by 1066Boy
Replied by 1066Boy on topic tyre pressures ?
Bigger the tyre the less pressure you normally need. 20 psi all round in mine.
  • gilburton
09 Oct 2016 10:55 - 09 Oct 2016 10:58 #173295 by gilburton
Replied by gilburton on topic tyre pressures ?
General rule of thumb (as above) is that the larger the tyre the softer the footprint so a lower pressure.
When a garage did a service on mine(standard tyres) I thought they had removed the springs as it was jarring at every bump.
They had only put them at 31 all round which is more like modern low profile tyres.
The Jimny has old fashioned tyres where the larger profile actually contributes to the suspension.
My wife sometimes looks at ours and says she thinks they are a bit low but when checked they are spot on but a lot can depend on how it is parked as it can make the tyre look soft.
Personally I would leave them at the standard pressures or even try the fronts slightly lower just to see the comparison.
I have a trike with huge tyres on the rear and run them at 15psi .
Last edit: 09 Oct 2016 10:58 by gilburton.
Time to create page: 0.086 seconds
