vacuum pipes
  • Cumbria fpv
04 Oct 2016 18:39 - 04 Oct 2016 18:46 #173157 by Cumbria fpv
vacuum pipes was created by Cumbria fpv
hi.
ive had my jimny for a year now ( Y reg 2001) and my four wheel drive never work. the green light would flash and 4wd would not engage etc. but it didn't bother because I didn't need it at the time.
a few weeks ago i tried putting it in 4wd and and it worked fine . and still does.
i took it for the MOT test today and when it was up on the lift i could see that the vacuum pipes had snapped clean off just after where the rubber pipe joins the metal ones
my question is how is it possible for the 4wd system to working be working when the pipes are broken off ?
and also will it doing any damage driving it like it is? if I'm right in the thinking the hubs are looked ?
thanks you in advance for any help.
Last edit: 04 Oct 2016 18:46 by Cumbria fpv. Reason: input year
05 Oct 2016 05:23 #173163 by kirkynut
Replied by kirkynut on topic vacuum pipes
I've no idea how this can be the case unless that side is locked through stiffness and one side doesn't leak across to the other. I have not paid enough attention to the pipework as I removed my as per my guide :
www.bigjimny.com/index.php/forum?view=topic&catid=7&id=55862
  • johna
05 Oct 2016 09:02 #173167 by johna
Replied by johna on topic vacuum pipes
sounds like they are locked on permanently. i think a lot of people do that with them, but if you are doing mostly sealed road driving best to fix them,( less things turning , and wearing out) which is not a easy thing to do and will probably stop working again in the near future, just to many seals,for the vacuum to leak around or do it the easiest way and change them to manual hubs.
  • Cumbria fpv
05 Oct 2016 10:51 #173171 by Cumbria fpv
Replied by Cumbria fpv on topic vacuum pipes
thanks for the replies guys. I do plan to use it more for off road in the future. although it did pass the mot it needs welding on the sills and rear body to chassis mounts. I will get all done at the same time. thanks again.
  • helijohn
05 Oct 2016 15:26 #173175 by helijohn
Replied by helijohn on topic vacuum pipes
I fitted manually operated front hubs and left them engaged all the time.
  • Cumbria fpv
05 Oct 2016 19:07 #173188 by Cumbria fpv
what manual hubs do you use ? i seen the ones just for the jimny. some priced at £160 and £110 ish.
Time to create page: 0.211 seconds
