IAT Sensor - where does it go ?
  • samui
04 Oct 2016 14:43 - 04 Oct 2016 14:45 #173147 by samui
IAT Sensor - where does it go ? was created by samui
Hi All
I just bought a 2005 1.3 4x4 soft top jimny that is missing the IAT sensor from the air box...problem is that i cant see where to connect this to after i buy a new sensor !
i dont see any hanging plugs that would help...diagram in service manual only shows filter side -- can someone help with pics if possible !
thanks in advance.
Last edit: 04 Oct 2016 14:45 by samui.
04 Oct 2016 15:58 #173148 by Jezz
You have sort of answered your own question. The IAT sensor (intake air temperature sensor) lives at the back of the air box, May differ a little on the different models/engines on each jimny, But should be there. Is the old one still installed and plugged in? If so there would be no available plug?
It's been fettled just a tad.
04 Oct 2016 16:05 #173149 by Jezz
  • samui
04 Oct 2016 16:16 - 04 Oct 2016 16:28 #173150 by samui
Replied by samui on topic IAT Sensor - where does it go ?
Thanks for the reply and pic.... I know it goes on the air box housing..problem is the other end. I dont see any connectors hanging unplugged..please advise. And no the hole is empty on air box...i can get a new one no worries but what connector goes to it and where doea that lead to ...cheers
Last edit: 04 Oct 2016 16:28 by samui.
04 Oct 2016 17:27 #173152 by Jezz
The plug connector is on quite a long bit of loom as i recall, So it may well of dropped down under the inlet manifold/fuse box or been tucked up out of the way by the previous owner.
  • samui
04 Oct 2016 17:46 #173153 by samui
Hey jezz im looking mate..cant see anything loose long or anything...where does it go to.???
