Flo-Flex polybushes fitting issue.
25 Sep 2016 19:28 - 26 Sep 2016 10:55 #172836
by HUN
TrailMaster 2" lift kit
ORE transfer box HD brackets
T-Max split charge system
Flo-Flex castor polybushes
Kumho KL71 tyres
AVM manual hubs
ORA radius arm guards
Push-fit breathers
Flo-Flex polybushes fitting issue. was created by HUN
Hello All,
I'm trying to prepare for a smooth installation of a 50mm Trailmaster Lift Kit bought few months ago for my Jimny. I try to do it properly using castor correction polybushes at both the front and rear arms but looks like I have size issues. Recently I bought a full set of second hand radius arms and refurbished them and put new Flo-Flex (Bits4Vits) polybushes into the spare arms to get ready for a smooth swap. Today I checked the available space on the original joint points. Guess what I noticed. At the 'arm to chassis' joint the bushes are to big (~70mm, see the photos) so it does not fit between the brackets (~65mm).
Did anyone have similar problem using genuine arms with Flo-Flex polybushes?
Kumho KL71 tyres
AVM manual hubs
Push-fit breathers
Last edit: 26 Sep 2016 10:55 by HUN.
25 Sep 2016 19:32 - 26 Sep 2016 10:53 #172837
by HUN
Kumho KL71 tyres
AVM manual hubs
Push-fit breathers
Replied by HUN on topic Flo-Flex polybushes fitting issue.
See the available space between the brackets. I admit the bush is also 65mm long but only when its out of the arm...When its fitted the thicker part of it which sits on the edge of the bore of the arm is too thick/long so it does not let the bush to sit properly in the bore. See the attached photos. Should I trim somehow? Any idea?
Kumho KL71 tyres
AVM manual hubs
Push-fit breathers
Last edit: 26 Sep 2016 10:53 by HUN.
- S200KYS
26 Sep 2016 08:53 - 26 Sep 2016 08:54 #172844
by S200KYS
Replied by S200KYS on topic Flo-Flex polybushes fitting issue.
I do wish people would contact suppliers before posting on discussion boards... :huh:
I fitted new bushes in my own (S200KYS blue Jimny) radius arms last week, and yes, they were a bit tight (better than them being loose though?!), and I will ask FloFlex to have a look at the dimensions again...
Mine are fitted and have helped ease my death wobble too...
If you're not entirely happy with them, please return them for a full refund...
Dave
Bits4Vits
Dave
Bits4Vits
Last edit: 26 Sep 2016 08:54 by S200KYS.
26 Sep 2016 10:51 #172848
by HUN
Kumho KL71 tyres
AVM manual hubs
Push-fit breathers
Hello Dave.
I respect your reputation and apologies if you feel this product is blamed. As I'm not a qualified mechanic just a simple Jimny owner it was not obvious for me what to do. Thought the forum is the best place to seek advice or share experience to help others posted my issue. I use them (in customised form) as I believe Flo-Flex bushes are quality products.
Regards, Gabor
Regards, Gabor
Kumho KL71 tyres
AVM manual hubs
Push-fit breathers
26 Sep 2016 13:35 #172853
Replied by Daniel30 on topic Flo-Flex polybushes
i purchased mine from Dave, Mine were a tight fit but fitted nicely (if you know what i mean)
- S200KYS
26 Sep 2016 13:45 #172854
by S200KYS
Thanks Gabor / Dan
I will drop a bush back to FloFlex so they can check it's dimensions to my spec'
Dave
Dave
Time to create page: 0.106 seconds
