Crank shaft sensor location
10 years 2 months ago #172531 by Me and my Jimny
Hi Guys
I finally got round to ordering the new sensor, and I wanted to check I was changing the right one when I get it, so I took a couple of pics hoping some will confirm if I've got it right
First one is of what believe is the crank sensor behind the alternator
Second one is a wider shot with that cavity being in the lower left
If anyone can confirm I've got it right, or set me straight, I'd appreciate it
Cheers
Paul
10 years 2 months ago #172538 by Keithy
Replied by Keithy on topic Crank shaft sensor location
That's the one!
10 years 2 months ago #172541 by kirkynut
Yep. That's it!
10 years 2 months ago #172549 by Me and my Jimny
Cool thanks guys
10 years 1 month ago #172822 by Me and my Jimny
Ok so I got it out but putting the new one in I snapped the bolt. Is it now a case of drilling it out and then re-tapping it for a new, slightly larger, bolt ?
I.e take it to someone who knows what they're doing before I do any more damage
Or is there an easier way ?
10 years 1 month ago #172823 by Keithy
You could try a left handed drill bit....or standard easy outs.....I thought the site had only one resident Gorilla? :D
Take care though as if you're not au fait with this line of work you could make things worse.
Time to create page: 0.122 seconds
