replacing steering box
  • rexthecat
10 years 2 months ago #172508 by rexthecat
replacing steering box was created by rexthecat
OK been a bit stupid....realised I put brake fluid in the power steering....bugger! was only a tiny bit but box started leaking. Cant tell quite where from, it always was a bit dodgy, so I guess I'll replace the washers on the banjo bolt where it originally had problems but if that doesn't work I guess I'll need to replace the box and hose. Whats the job like to do? seems a bugger to get into as the body lift makes it a long way down. Do I need to get a pitman arm puller?
Ta
10 years 2 months ago #172514 by kirkynut
Replied by kirkynut on topic replacing steering box
Soak the pitman arm clamp with wd40 for a few days. Then undo the nut and hit it from both side at the same time with a hammer to see if it will free off.
If not a standard two sided puller would do I suppose. I've not had the need to do it!
  • wombat
10 years 2 months ago #172547 by wombat
Replied by wombat on topic replacing steering box
Hi, if you are changing the steering box, warm the steering arm up with a blowlamp first as it will not matter if you destroy the seal in the steering box :)
Time to create page: 0.196 seconds
