Wheel bearings
- mic888
15 Sep 2016 21:16 #172376
by mic888
Wheel bearings was created by mic888
Hiya people just a quick one, my half shaft oil seal has been leaking but i cant feel any play in the wheel bearing. I have replaced the king pin bearings and oil seal but its still leaking, i was just woundering should there be up and down float on the half shaft when the freewheeling hubs are removed.
Thanks mick
Thanks mick
24 Sep 2016 20:57 #172807
by bryn
Replied by bryn on topic Wheel bearings
i have the same problem. Im thinking of replacing the half shaft next. I would be interested to see if you can come up with a solution
bryn
bryn
- mic888
24 Oct 2016 10:43 #173864
by mic888
Replied by mic888 on topic Wheel bearings
I seem to have solved the problem so far I've done 100 miles with no leaks, where was before I would do 10 miles then the jimny would be marking its territory. What I have done this time was bought a genuine seal from my local Suzuki garage, this seal was made from a much softer rubber and also was a much tighter fit over the half shaft. Hopefully the jimny will remain leak free.
Michael
Michael
- mickt
24 Oct 2016 18:53 #173871
by mickt
Replied by mickt on topic Wheel bearings
Your first post was a bit confusing. Which end of the car was leaking. The front or the rear?
- chechan rebel
25 Oct 2016 11:53 #173890
by chechan rebel
Replied by chechan rebel on topic Wheel bearings
Not real sure whats confusing? Only one end of the rig has king pins, an thats the front....
- mickt
25 Oct 2016 18:09 #173899
by mickt
That is true. The half shaft term had me thinking rear for some reason.
Time to create page: 0.101 seconds
