fault code
  • talby2491
10 years 2 months ago #172350 by talby2491
fault code was created by talby2491
Has anyone ever had the fault code p0171 system to lean code if so how did tou rectify the problem getting a very strong whiff of petrol when the roof is down hoping this is the problem thanks in advance
10 years 2 months ago #172353 by mlines
Replied by mlines on topic fault code
DTC P0171 Fuel System Too Lean
• Vacuum leaks (air drawn in).
• Exhaust gas leakage.
• Heated oxygen sensor-1 circuit malfunction.
• Fuel pressure out of specification.
• Fuel injector malfunction (clogged or leakage).
• MAP sensor poor performance.
• ECT sensor poor performance.
• IAT sensor poor performance.
• TP sensor poor performance.
• EVAP control system malfunction.
• PCV valve malfunction.
  • mickt
10 years 2 months ago #172360 by mickt
Replied by mickt on topic fault code
The smell of petrol is the first fault to trace and that should hopefully answer the message problem. Is the fuel cap sealing ok?
10 years 2 months ago #172592 by facade
Replied by facade on topic fault code
Check for a fuel leak from where the pipes corrode at the bend under the driver's feet.
Time to create page: 0.095 seconds
