New wobble
- grumyoldjoe
- Elite Member
- Thank you received: 19
11 Sep 2016 08:05 #172181
by grumyoldjoe
Wine improves with age.
New wobble was created by grumyoldjoe
Couple of months ago posted about an issue. Had no wobble but was leaking diff oil so after advice on here went ahead and changed bearings and seal.
NS tyre had run off a bit so at same time put my unused spare on.
Now I have a nasty wobble when braking at 40mph area. No wobble when accelerating up to 80 and no wobble coming down until around 40.
Have jacked up and tried to move wheel side to side and top bottom and get no movement.
Spare put on is balanced I think as weights are still on. Pressures are ok all around at 23psi. tyres have 5mm plus apart from spare which is new at 8
Never had this issue before kingpin bearings changed so confused.
Any ideas ?
btw its a 2013 with 25000 on clock
Any ideas ?
- mickt
11 Sep 2016 09:11 #172183
by mickt
Replied by mickt on topic New wobble
Get the spare rebalanced and ensure the pressures are correct. As the original tyre had uneven wear I would get the tracking checked too. That all done then if it still happens try swapping the wheels front to rear in case the spare is not true in rotation. You could then follow the advice given in the "Wobble" thread in this section.
11 Sep 2016 15:45 #172194
by Halford
Replied by Halford on topic New wobble
I'd try putting the two rears on the front first - equally worn tyres and see what happens.
probably the fact that you've a new tyre on n/s and a worn tire on o/s that's the problem as the slightest little thing causes issues with a jimny front end, and 40 mph is death wobble territory
The following user(s) said Thank You: grumyoldjoe
11 Sep 2016 19:33 #172203
by Rhinoman
Replied by Rhinoman on topic New wobble
Did you shim the kingpins? you may need to add a little preload as per the Technical Service Bulletin - its available on this site. How did you remove the old bearing races? I had an issue with mine where a previous owner had used a screwdriver or something similar and had damaged the surface that the bearing sits on so it was ever so slightly wonky. I had to scrape it flat again.
- grumyoldjoe
- Elite Member
12 Sep 2016 19:13 - 12 Sep 2016 19:15 #172239
by grumyoldjoe
That did the trick::
Great suggestion as I found some rust underneath that needs doing and I also found out how shit my halfrauds trolley jack is as well.
Dont lift the car that high and also drops at speed when releasing.:ohmy:
Thanks guys for all the inputs.
Replied by grumyoldjoe on topic New wobble
Cheers HalHalford wrote: I'd try putting the two rears on the front first - equally worn tyres and see what happens.
Last edit: 12 Sep 2016 19:15 by grumyoldjoe.
13 Sep 2016 04:09 #172253
by Halford
happy days
but rest assured the wobble will be back, they should have called it the suzuki jelly not jimny.
Time to create page: 0.098 seconds
