Whining sound
  • jim
  • Visitor
  • Visitor
15 Sep 2016 21:50 #172379 by jim
Replied by jim on topic Whining sound
Here's when I did my gearbox oil its very easy to do just a bit messy.
www.bigjimny.com/index.php/forum?view=to...id=7&id=58818#154118
16 Sep 2016 07:08 #172382 by BGBrit
Replied by BGBrit on topic Whining sound
Gus and Jim, Thanks indeed... I take it we are all happy, mine is a jlx vvt model. In which case, I'll go ahead and get the oils recommended. Thanks for all the advice and I'll keep you posted on my success or failure. I do have a 10mm square drive and an 18" cracker bar, and I'll take care cleaning out the drive holes. Just need to find a Bulgarian supplier for the oils, Easy said than done, I can assure you of that.
Many thanks, take care!
Tony.
  • jim
  • Visitor
  • Visitor
16 Sep 2016 16:51 - 16 Sep 2016 17:05 #172418 by jim
Yes Tony the m13aa vvt R72 box. I've just had mine re conditioned because of a whine in 3rd and 4th. Apparently it's quite common my bearings were complete mush. If you have to go down this route there is a drop in kit which you can buy, my mechanic friend rebuilt it so I saved a fair bit.
Last edit: 16 Sep 2016 17:05 by jim. Reason: Pic
16 Sep 2016 17:03 #172419 by BGBrit
Well Jim,,, Let's hope the oil changes does the trick first, fingers crossed... Mine has only done 37,400 miles, but in that time both front kingpin bearings have failed and been replaced. These are common faults too,,, so is the rust which is everywhere, why did I buy one!!!!!!
Seriously, though, at what mileage does the gear bearings normally give way? I would have thought after 100,000 miles but it's only a guess.
If the whining persists after the oil change, I'll look into it further.
Cheers..
  • jim
  • Visitor
  • Visitor
16 Sep 2016 17:09 #172420 by jim
I know what you mean these jimnys are a bit of a pain. You should be alright Tony mine had done over 80k before the whine started.
19 Sep 2016 09:14 #172563 by BGBrit
Below is a gear oil which is supplied in Bulgaria, which is easily available to me. From reading the spec it looks like I could use them for the whole lot, transfer, diffs and gears. Using the right grades of course. What do you think? Has anyone used these with success? As far as I understand the oil doesn't contain sulfur, but apparently still okay for the diff's...
bgmasla.com/?product=hilber-syngear-75w90-2
An extract from the site below...
Hilber Syngear 75W90 is a synthetic oil for the entire transmission line of cars (Total Drive Line), including synchronized and unsynchronized manual transmissions, transmissions with and without hypoid gearing and transfer case with cars and trucks.
typical method Unit Hilber Syngear 75W90
SAE class DIN 51512 - 75W-90
Density at 15 ° C DIN 51757 g / cm3 0.866
Viscosity at -40 ° C CEC L18-A80 mPa.s 66000
Viscosity at 40 ° C DIN ISO 3104 mm2 / s 101
Viscosity at 100 ° C DIN ISO 3104 mm2 / s 15
Viscosity index (VI) DIN ISO 2909 - 157
COC flash point DIN ISO 2592 ° C 190
fluidity DIN ISO 3016 ° C -48
Time to create page: 0.136 seconds
