Nuts & Bolts
- Venter
06 Sep 2016 16:11 #172060
by Venter
Nuts & Bolts was created by Venter
Hi folks, I'm looking at doing both kingpins shortly.
Last time I did them, I pretty much trashed most of the fixings in/around the hub. I managed to get everything fastened up again, but know that this time around they'll be unusable once removed.
I've got some front hub bolts already, but need the small ones that hold the swivel seal on, as well as the ones holding the kingpin on. I might be missing some out.
Does anyone know where to get these?
Or if not, know what each of their specifications are (i.e. size, thread pitch, etc)?
06 Sep 2016 16:40 #172061
by Busta
Replied by Busta on topic Nuts & Bolts
They are all standard metric bolt sizes so remove one of each and take them to your local bolt shop.
The only difference will be the kingpin bolts are (from memory) M8 and the replacements will have a standard 13mm head, rather than the smaller 12mm used by the (deeply superstitious) Japanese.
- auchenblae
- Elite Member
- Thank you received: 25
06 Sep 2016 22:34 #172080
by auchenblae
eddie
24 Swift Ultra ALLGRIP
16 SZ3 gone 25
07 JLX+ gone 16
99 JLX gone 07
Replied by auchenblae on topic Nuts & Bolts
Make sure they are at least grade 8.8, grade 10.9 is stronger.
Do not use stainless as they do not have the give for shock loading that suspension and hub bolts need.
eddie
16 SZ3 gone 25
07 JLX+ gone 16
99 JLX gone 07
- Venter
07 Sep 2016 18:55 #172104
by Venter
Replied by Venter on topic Nuts & Bolts
Thanks for the info chaps, will be heading out into the big wide world to try find some...
08 Sep 2016 08:01 #172121
by facade
Also, don't use stainless bolts anywhere into alloy, as they will never come undone again
Replied by facade on topic Nuts & Bolts
auchenblae wrote: Make sure they are at least grade 8.8, grade 10.9 is stronger.
- auchenblae
- Elite Member
08 Sep 2016 08:10 - 08 Sep 2016 08:12 #172122
by auchenblae
eddie
16 SZ3 gone 25
07 JLX+ gone 16
99 JLX gone 07
Agreed Facade the easy way is just to say carbon steel everywhere on cars!
eddie
16 SZ3 gone 25
07 JLX+ gone 16
99 JLX gone 07
Last edit: 08 Sep 2016 08:12 by auchenblae.
Time to create page: 0.088 seconds
