rear end clonk
- Antelope
05 Sep 2016 20:54 #172033
by Antelope
rear end clonk was created by Antelope
Hi
If I drive in first, second or third, take my foot of the accelerator without depressing the clutch, and then reapply power, I get a 'clonk' from the rear end. Would this be a UJ issue? Or differential? Or even suspension? Or something else?
thanks
D
thanks
D
- Thank you received: 2004
06 Sep 2016 04:06 #172044
Replied by Lambert on topic rear end clonk
Yes. Though I would check the axle last as it is both more expensive and more difficult than uj's and suspension.
The following user(s) said Thank You: Antelope
06 Sep 2016 12:40 #172054
Replied by Daniel30 on topic rear end clonk
Check your exhaust is knocking about
- Thank you received: 706
06 Sep 2016 14:18 #172056
Replied by jackonlyjack on topic rear end clonk
radius arm bushes/are the bolts tight
rear shock bushes again loose bolts
Jack
Jack
- Antelope
06 Sep 2016 14:45 #172058
by Antelope
Replied by Antelope on topic rear end clonk
Thanks all. I'm going to take it down to my local friendly Cretan mechanic tomorrow in the town of Chania, put the car up on a ramp, and have a poke around underneath. Only just bought it, so if there is a significant problem, I hope to get it paid for.
06 Sep 2016 18:50 #172066
by Rhinoman
Replied by Rhinoman on topic rear end clonk
Check around the rear axle mounting holes, the bolts can come slightly loose and the holes go oval.
Time to create page: 0.096 seconds
