Won't start, Won't crank ?
- shiponthewater
29 Aug 2016 04:56 #171820
by shiponthewater
Won't start, Won't crank ? was created by shiponthewater
Any ideas on this one ..
1999 Jimny, G13bb engine,
was starting and running nicely,
now won't start, won't crank when key turned to start,
battery ok, all lights on dash ok - no fault lights,
battery connections ok,
no sound of clicking of starter solenoid or relay ,
any help most welcome .......
29 Aug 2016 06:05 #171823
Replied by Riccy on topic Won't start, Won't crank ?
Have you tried to tap the starter solenoid with a bashing stick? mine went and the click noise was so quiet i couldnt hear it unless under the car. spent ages messing around thinking it was the immobiliser!
Ricc
Ricc
The following user(s) said Thank You: shiponthewater
- shiponthewater
30 Aug 2016 05:35 #171850
by shiponthewater
Replied by shiponthewater on topic Won't start, Won't crank ?
Thanks Ricc, I'll have a go at the starter, I lost hope thinking it had to be the ECU ...
- shiponthewater
30 Aug 2016 13:20 #171862
by shiponthewater
Replied by shiponthewater on topic Won't start, Won't crank ? FIXED
FIXED ...
The spade connector on the solenoid was loose and obviously dirty and worn,
so worn that after cleaning (difficult enough with the car only jacked up)
was too loose to be secure for long, my quick fix for this was to rip a short
length of flat brass tie (about 20thou thick) from inside an old 13amp socket
and insert this into the female connector as I pushed it onto the solenoid.
Good and firm now, but not ideal ...
many thanks to Riccy for the quick reply to my post ....
Graham
Graham
31 Aug 2016 07:58 #171881
Replied by Riccy on topic Won't start, Won't crank ? FIXED
Your welcome, i found that trick worked for a while but started to play up again on wet days, eventually the starter was replaced and problem solved. garage said it was an awful job to get at it!
Also ive put some brown electrical waterproofing compound around it (called monkey shit, is like sticky play-dough but non conductive)... working well so far.
Riccy.
Riccy.
Time to create page: 0.099 seconds
