Drive Train Lash...
  • gusthegorilla
10 years 2 months ago #171746 by gusthegorilla
Drive Train Lash... was created by gusthegorilla
Spent the morning investigating a case of excessive lash/snatch, or whatever it's called, when taking up the drive.
Ruled out the gearbox mount, radius arm bushes/bolts, t/box mountings and prop joints, but seems to be a lot of play in the rear differential.
Dropped the oil out and found a large wad of filings on the magnetic plug.
Is it safe to assume that a replacement diff is required, or is there a way to take out the play?
If new diff is required, would it be prudent to change out the seals and bearings while it's all apart, and how difficult a job is it overall?
Do I need any special tools other than a massive slide hammer ? :woohoo:
Thanks, as always,
Gus ;)
  • helijohn
10 years 2 months ago #171768 by helijohn
Replied by helijohn on topic Drive Train Lash...
gusthegorilla wrote: Dropped the oil out and found a large wad of filings on the magnetic plug.Gus ;)
Was it furry in nature or did it have bits?
  • gusthegorilla
10 years 2 months ago #171769 by gusthegorilla
Replied by gusthegorilla on topic Drive Train Lash...
No, it was furry, like very fine valve grinding paste. .....you got a theory, John ? :huh:
  • wombat
10 years 2 months ago #171771 by wombat
Replied by wombat on topic Drive Train Lash...
Hi Gus, furry could be normal if the oil hasn't been changed for a while, i'd see what it's like with new oil in. There always seems to be a lot of backlash in jimny axles
If needed i have a massive slide hammer
Ian
  • gusthegorilla
10 years 2 months ago #171776 by gusthegorilla
Appreciate the thought, Ian....Many thanks for that ;)
I'll run it for a while with the fresh lube, but there seems such a lot of lash that I'm changing gear extra smoothly so I don't break anything !! There are no other associated noises to go with it so there may be something in what you say about Jimny axles, I know there is some in Ellie's Jim but not nearly as much, and my fastback has none at all :huh:
Gus
Time to create page: 0.095 seconds
