Front Diff Question
  • ME13OSE
10 years 2 months ago #171601 by ME13OSE
Front Diff Question was created by ME13OSE
After fitting a set of manual locking hubs I still had the front of the jimny on axle stands, as I was fitting wheels spacers also, I noticed that with both hubs locked and fully engaged when I spin one wheel the other did not move, but the propshaft turned. This was the same regardless of which side I spun, other wheel always stayed still.
This goes against what I know from working on cars all my days. The other wheel would turn in the opposite direction, with the exception of my track cars as they have LSD's in the box's.
Is this normal before I pull the half shafts and diff out of it?
10 years 2 months ago #171602 by j999pre
Replied by j999pre on topic Front Diff Question
Normal if you were in 2wd on the transfer box. Stick it in 4wd are with the hubs locked Ave one front wheel in the air you shouldn't be able to turn it. 2 front wheels in the air the other will go backwards
Grey pick up Jimny
The following user(s) said Thank You: ME13OSE
  • ME13OSE
10 years 2 months ago #171605 by ME13OSE
Replied by ME13OSE on topic Front Diff Question
I was lying under it earlier and held the front prop, spun one wheel with both off the ground and the other rotated in the opposite direction. Something doesn't feel right in the diff though, it will spin smooth then bind up, almost pulling the prop from my hand as I held it to stop it rotating. I'll have the front diff stripped and checked when the rear lock right goes in.
  • helijohn
10 years 2 months ago #171802 by helijohn
Replied by helijohn on topic Front Diff Question
ME13OSE wrote: I was lying under it earlier and held the front prop, spun one wheel with both off the ground and the other rotated in the opposite direction. Something doesn't feel right in the diff though, it will spin smooth then bind up, almost pulling the prop from my hand as I held it to stop it rotating. I'll have the front diff stripped and checked when the rear lock right goes in.
Have you had someone hold the other wheel while you turn a wheel and maybe hang on to the prop?
10 years 2 months ago #171835 by facade
Replied by facade on topic Front Diff Question
ME13OSE wrote: Something doesn't feel right in the diff though, it will spin smooth then bind up, almost pulling the prop from my hand as I held it to stop it rotating.
Check the CV joints too.
Time to create page: 0.077 seconds
